Ballast what about RV antifreeze ?
   / Ballast what about RV antifreeze ? #11
it don't seem good to put a water based liquid in your tires, water on steel makes it rust..(steel rims)..
You have the rears loaded on that hugh JD La 145 don"t ya??
   / Ballast what about RV antifreeze ? #12
I was able to get propylene glycol rv antifreeze for $1 a gallon late last winter from rural king as they were trying to get rid of there stock before spring. They had 7 pallets of the stuff at the store closest to me after I bought 98 gallons.
   / Ballast what about RV antifreeze ? #13
When I bought my tractor in 2004 I found that the Kubota dealer loaded it with windshield washer fluid, so that's what I use.
Chris
   / Ballast what about RV antifreeze ? #14
Chris
Yep. $200 bought me 1400lbs of weight. No brainer for me.
   / Ballast what about RV antifreeze ? #15
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
16ft. T/A Utility Trailer (A56859)
16ft. T/A Utility...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
