What to do with old gas cylinder
   / What to do with old gas cylinder #1
goddom
Flat Rock, MI
LS G3038H
So I got these 4 old gas cylinders that were given to me because the person who had them didn't know what to do with them. They are all about 250 cubic foot full sized cylinders that were literally dug out of the ground in Detroit. All of them are pretty old and hadn't been hydro'd for at least 20 years. One still had the steel cap and valve on it, one was missing a valve completely, one had a valve and one had a broken off valve. It turns out, one of them was probably made in 1950, and the last hydro test was in 99 if I remember correctly.It was the one that didn't have a valve on it so I decided to cut that one up. Silly me thought it would be fun to turn it into a giant wind chime so I am in the middle of doing that. I have it mostly together but I need to find something (probably a big ***** tree) that is burly enough to hold the darn thing. I think it weights about 70-80lbs.
I shot a video about cutting it open and looking inside if you want to see what a 70 year old gas cylinder looks like on the inside: Cutting Open 70yr Old Gas Cylinder - Weld Project - YouTube
I think the one that had the valve still on it, I think I am going to use that as a reservoir for my air compressor. I have kind of a small 15 gallon air compressor so I thought having this might help increase the capacity of my system and I don't have to worry about the cylinder containing the 150psi from my compressor.
Another one my friend wants to use, potentially, to make a forge out of.
I have one more air cylinder I have no idea what to do with. Any thoughts? I could just scrap it, but it seems like a waste. Maybe there is something fun or interesting to do with it instead.
   / What to do with old gas cylinder #2
Do you have a shooting range of your own? Cut in half they make great gong targets for long range. No mistake on a hit.
That's a good idea! I don't do much shooting nowadays, but my neighbor does a ton and so does my brother-in-law. I have a few pieces of one that I can give them for that.
   / What to do with old gas cylinder #4
don't use it on your air compressor, it will take a very long time to fill up, and then a very long time to fill again when you use up the air. your air compressor will get very hot trying to keep that tank filled!.. here's a good use for the cylinder. This DIY Bowling Ball Cannon is Dangerously Fun although I'd just use it for the noise, NOT put a bowling ball or other projectile in it, just the black powder..
   / What to do with old gas cylinder #5
Let me help you understand what is being discussed. The tank volume is about 11.5 gallons.
   / What to do with old gas cylinder #6
I have a group of personal trolls that follow me, which I have blocked, so I hope they don't interfere with you..
   / What to do with old gas cylinder #7
Probably because you continuously post stupid, wrong, or irrelevant post.
   / What to do with old gas cylinder #8
I've turned a few of them into yard art. Gongs, prayer wheels. They seem to hold chain real well to without it getting all bound up in or out.
   / What to do with old gas cylinder #9
They seem like a pretty terrible shooting target. A flat piece of steel angled down will controllably direct the rounds into the dirt. A round target is going to ricochet everywhere.
   / What to do with old gas cylinder #10
1950 is not that old of a cylinder. Do they have a name stamped into the cylinder neck? Many that size are leases only.
John Deere 3025E (A53317)
John Deere 3025E...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Mobile toilet with shower (A53424)
Mobile toilet with...
