Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,971
It would probably be a lot cheaper and more practical to supplement a firewood burner with waste oil. I could get at least 500 gallons of that for free. I知 gonna disagree with more uniform drying before chipping. The first problem is wood left in the woods never really drys. It starts rotting from day one. The part of the top held off the ground will dry more than the parts on the ground. And the big parts will dry slower than the smaller parts. After it痴 chipped drying time could be reduced to only a couple days on a hot day in the sun and everything is uniform size.
My father in law drives me up the wall in the winter. He "burned wood for 30 years" and just dropped the red oak the year before and let it lay on the ground then bucked and stacked as needed so like 8 rounds bucked and stacked then split just before he threw it in the stove. He would then let it smolder for a while until it took off then shut it down. I can't believe he didn't have more chimney fires. He had the nice sticky goo drip down the back of the wall thimble at one point. I told him it wasn't dry and he insisted it was. He makes fun of me for the CSS 6 cords I do every year around June to get 1 year ahead. It only takes a 3 days with my dad and I also being a school teacher my summers aren't usually that busy.
I burn almost all ash with some red maple and cherry mixed in, but with my EPA wood stove I can heat a 3100 sq.ft. house with 3 loads of wood in the dead of winter 10*-20* outside temps. I'm not complaining and it wouldn't do that with wet wood. I tried burning some 1 year seasoned cherry at the end of the winter when I ran out of seasoned wood. After 1 week of fighting it I just turned on the furnace.
I've thought about building a gasification furnace using chips but the time, effort, and money I figure could be put into cutting wood and be about the same.
   / Tractors and wood! Show your pics #9,972
My dream stove would burn wood chipper chips easily obtainable for free and no work that’s auger fed from a hopper. Free heat and little work seems like a win win.
There are residential sized wood chip boilers already available. They are a bit particular about the size of chips they use, so they don't run well off of chips from the typical back yard chipper. The large commercial-sized wood chip boilers are designed to run off of green chips, so no drying is necessary. The green chips do require inside, heated storage (above freezing, so they don't freeze together into one large block).
I used to work with a guy who was a wood combustion guru. He was designing a residential wood-chip boiler which would use what he called an "energy chip". Those wood chips needed to be dried below the fiber saturation point (generally around 30%, depending on species). Getting to that point is relatively easy when drying. It's getting below that point that takes more time and energy. The advantage was that all they needed was covered storage, not heated: they will not stick together in freezing temps if below fiber saturation point. He ran into financial difficulties and it never made it into production.
   / Tractors and wood! Show your pics #9,973
We got the Tarm specifically because of its gasification ability, which when in operation produces literally zero smoke from the stack.
It is solid cast iron and weighs in at 1500 lbs.
The older outdoor boilers are smoky rigs although I have heard that they are now available with gasification.
I like my tarm. Doesn't like wet wood, that's for sure. With the heat storage tank....it's extra nice.
   / Tractors and wood! Show your pics #9,974
Not really a tractor, but it will be used like one on occasion:
I bought this 1952 M37 Truck a couple of weeks ago - mostly to have a vehicle with some character to drive around on local trips and occasionally take in the woods to grab firewood.
I'll be fixing up or replacing a few things on it, but the intent is to keep that "it's been around the block a few times" look, not to have a showpiece. Still need to figure out how I'm going to address the fact that it has a pintle hitch, and all of my trailers are set up for a 2" ball.
I like that it still has the fold-up troop transport seats in the back. I may look in to adding the hoops and canvas top over the back. The current tires are 11.00x16 which are a few inches oversized for this vehicle. I'll probably eventually switch them back to 9.00x16 which was the stock size,
Nice Purchase!! I've always wanted a Kaiser m715, but this was a close second.
   / Tractors and wood! Show your pics #9,975
It definitely needs very dry wood, thus the small size of the wood I split and the heat storage tank takes it above and beyond any conventional wood burning appliance.
This time of year I can go 3 days between firings.
   / Tractors and wood! Show your pics #9,976
Or more, at least for me.
Mine's 1600gal. An old fuel tank, and it's buried outside the basement wall. I lose heat for sure vs it being in my basement (good in summer, bad in winter).
   / Tractors and wood! Show your pics #9,977
Mine is a 650 gal stainless steel maple sap tank fully insulated in my basement; what little heat is lost ends up in my living room which is directly above the basement.
   / Tractors and wood! Show your pics #9,978
Trees dry surprisingly well if you cut them in June and let the leaves suck the moisture out. Standing trees which die deteriorate much faster than a tree which loses it's top and just stands there. As you point out however, they still need to be opened up to let air in, and get the wood fully dry. Oak takes two years to dry anyways, while common lore has it that ash can be burned the day which it was felled. That may be the case, yet it still burns better when seasoned.
   / Tractors and wood! Show your pics #9,979
Yes them 50 year old McCulloch chainsaws will do that to ya...................
I haven't run a 50 year old McCulloch, but a 40 year old one was one of the first I ever ran. Mom would have clobbered Dad if she knew I was running one at 13-14.
I saw one just like it pop up on Craigslist last week that needed a clutch. Almost jumped at it for nostalgia, but I don't know that I need a 3rd saw and wasn't sure I could find a clutch.
   / Tractors and wood! Show your pics #9,980
I have a 45 year old McCulloch Pro Mac 55, that I bought new...
It set's in the barn, never used...
SR
2018 Bell B30E 30 Ton Articulated Dump Truck (A52377)
2018 Bell B30E 30...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
