Cleaning your Hydraulic Connections/Connectors
   / Cleaning your Hydraulic Connections/Connectors
Thank you countrybumpkin.
If it's been good to you over 40 years of use, it must be fine to use.
Thanks again.
   / Cleaning your Hydraulic Connections/Connectors #12
Brake clean wont hurt any seals. I would love to seebsomeone try to clean dirt out of one of these couplers with hydraulic oil...then i would love to see the dirt caked oily mess after a weeks work.
   / Cleaning your Hydraulic Connections/Connectors #13
That’s what we like about the starting fluid, it has a pretty high psi out of the can , evaporates quick, and cuts the grease and oil.
   / Cleaning your Hydraulic Connections/Connectors #14
I use brake cleaner also, for most hygiene requirements where petroleum products are concerned. Unlike carb cleaner and such, most types don't attack most painted surfaces. Air or a rag cleanup.
So maybe have several decent choices..... Brake Cleaner, WD40 or Start Fluid.
   / Cleaning your Hydraulic Connections/Connectors #16
I certainly DO recommend cleaning the couplers before connecting them, I am currently replacing 3 leaking couplers and I am pretty certain that the leaks would have been prevented had I cleaned them better than just a quick wipe with a rag. The couplers I have and I'm certain most have end up costing around $15-20 each so that can add up over time.
   / Cleaning your Hydraulic Connections/Connectors #17
The easiest solution is to change them out for flat faced skid steer couplings which are easily cleaned with your hand or a dry rag. For the ag style couplings a compressed solvent like starting fluid or brake cleaner is the best way. Swirling them in hydraulic fluid is a ridiculous mess that wouldn’t even work.
   / Cleaning your Hydraulic Connections/Connectors #18
I totally agree that, that is the easiest solution, and I considered it, however the price scared me away, the price at my local hydraulic supply store was $90+ EACH, I found some online but they were still around $80 each, so I quit looking. I don't blame anyone for making that switch, it just didn't work for me.
   / Cleaning your Hydraulic Connections/Connectors #19
Cleaning them is correct procedure but that’s why I use flat face connectors just wipe them off
   / Cleaning your Hydraulic Connections/Connectors #20
I like WD40, its a great cleaner. I'm always concerned that Brake Clean or other harsh cleaners/solvents will damage the o-rings-probably unfounded though.
Ditto on this - I carry a small can and a role of wipes with me on the tractor, It also works as a hand cleaner.
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
207281 (A52708)
207281 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
