Bump up lift capacity of L3400/LA463 Loader
   / Bump up lift capacity of L3400/LA463 Loader #361
Just about all manufacturers sell their sub-compacts and compacts running @ about 2,700psi from the factory, using comparable components.
I have no idea why Kubota sets theirs so low. I bumped mine @ 2,650psi few years ago, and she has been great!
Only thing is, I had to increase the weight of my counterweight from 1,100 pounds to 1,400, as I started lifting the rear end once I bumped the pressure.
All the ones I'm aware of are 2,500psi or so. Skid steers are generally 3,000psi nominal. Excavators are commonly in the 5,000 range up to 8-10k or something.
A lot of the hydraulic hose you find in the farm stores is rated to 2,500.
   / Bump up lift capacity of L3400/LA463 Loader #362
34 pages. Could someone that has increased the pressure to the loader put together a "How to" with pictures?
   / Bump up lift capacity of L3400/LA463 Loader #363
I believe there are YouTube videos. When I did mine the hardest thing was opening the package the washers came in..... It's a really simple process.
   / Bump up lift capacity of L3400/LA463 Loader #365
Thank you.
   / Bump up lift capacity of L3400/LA463 Loader #366
Created an account just to say this thread is really great. Couldn't lift a roll of hay....had to scoot it across the ground. For going on 10 years. Found this. Ordered a gauge from Tractor Innovations. My pressure was at 2200psi. I had 3 washers in there mearsuring a combined 2.8 mm. To get an extra 300 psi (for a total of 2500 psi), I knew I needed 3.5mm of shims (washers). I kept combining different washers until I reached 3.5 mm. Put it all back together, and 2500 psi on the nose! Very easy job. I found the washers in my supply of machine screw hardware...they are small. Not sure what size. I changed my fluid/filter at the same time, and found that I had an extra 1.5 gallons in the system.....now it is spot on, so I killed two birds with one stone, so to speak. Great thread and thank you.
   / Bump up lift capacity of L3400/LA463 Loader #367
Look to Messicks for a video debunking the value of the increase (quoting increases of moderate per cent) saying it's not worth the effort and a section of the video showing the result of one such test by a Youtuber that got a 6% increase on a BX.
AND IF you can use a search engine with a phrase like:
adding shims to kubota loader valve
You should be able to get a page or more of results like:
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Dewalt DWM120 5" Deep Cut Variable Speed Band Saw (A59076)
Dewalt DWM120 5"...
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
500 BBL FRAC TANK...
2012 MACK GRANITE - GU713 (A58214)
2012 MACK GRANITE...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
