FEL & 3pt hitch not working after oil/filter change
   / FEL & 3pt hitch not working after oil/filter change #11
On hydraulics and engines it is best to fill the filter for two reasons: 1) The pump can draw oil right away instead of a slug of air. 2) Oil pressure impacting a dry filter element can potentially rupture it rendering the filter useless.
Any tricks to filling one horizontally mounted?
I would not run the engine till I had pulled oil thru the pump those pumps do not like being run dry very long.
Might be a little late for this one Wish me luck.
Which ever is the easiest, at the valve will give you a hose to stick in a bucket.
If the filter hangs down vertical it might help if it's horizontal it is hard to do.
It worked! I removed a plug in the top of the pump and used a rubber tube for the vac, which might expect why it took a while... The wait did give me time to pull the filter and dump fluid all over the driveway...
Everything is working great! Thanks for the help!
   / FEL & 3pt hitch not working after oil/filter change #15
Good to hear.
Adams 5 ton Fertilizer Buggy / Wagon (A52128)
Adams 5 ton...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
2 Row Cultivator (A52128)
2 Row Cultivator...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
