FEL & 3pt hitch not working after oil/filter change
   / FEL & 3pt hitch not working after oil/filter change #11
On hydraulics and engines it is best to fill the filter for two reasons: 1) The pump can draw oil right away instead of a slug of air. 2) Oil pressure impacting a dry filter element can potentially rupture it rendering the filter useless.
Any tricks to filling one horizontally mounted?
I would not run the engine till I had pulled oil thru the pump those pumps do not like being run dry very long.
Might be a little late for this one Wish me luck.
Which ever is the easiest, at the valve will give you a hose to stick in a bucket.
If the filter hangs down vertical it might help if it's horizontal it is hard to do.
It worked! I removed a plug in the top of the pump and used a rubber tube for the vac, which might expect why it took a while... The wait did give me time to pull the filter and dump fluid all over the driveway...
Everything is working great! Thanks for the help!
   / FEL & 3pt hitch not working after oil/filter change #15
Good to hear.
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
