Ventless wall mount natural gas heater
   / Ventless wall mount natural gas heater #11
I'm still reading up on these and was reading some comments and someone mentioned that gas cooking ranges and stove are ventless and don't seem to cause an issue. I don't know if that is a good comparison though. I'm trying to talk myself into buying one as you can see. :) I see a lot of negatives thoughts on ventless, but then again, I'm using it for supplemental heat, so I don't see it being an issue.
I would be 100% confident. I have been doing gas installs since 1980 and have always serviced what I sold. That being said my wife has a better sense of smell than I do but she did not have any complaints either.
That makes me feel good to hear.
   / Ventless wall mount natural gas heater #13
Have you looked into a mini split? My buddy spent under $1000 and has been very happy with his.
No, do you mean like a heat pump?
   / Ventless wall mount natural gas heater #15
I put one in my workshop and in my garage and both work great. In our area whenever I go to someones house it is very common to see. I never heard anything negative about using them. Cheap and easy to install.
   / Ventless wall mount natural gas heater #16
Yes heat pump in the winter and AC in the summer. My buddy’s was kicking out 100.6°f air when it was 26°f yesterday morning.
   / Ventless wall mount natural gas heater #17
I have an Empire 30K Blue Flame propane wall mount in my living room for emergency heat. I run it every few years, then make sure it is clean and wrap it in plastic. Works great.
   / Ventless wall mount natural gas heater #18
I have a 20,000 btu propane unit I use to heat a 2,000 sq ft house. It's all I use. I have used it for the last 6 years or so. No problems with moisture or smell. 99% efficient... My propane bill went down considerably. My central heating units only get turned on if we get in the low teens. Pretty much never. Your one room? No problem.
   / Ventless wall mount natural gas heater #19
Hello,
I have never owned a ventless heater so I'm only going by what I heard, but I have heard that the ventless ones leave a film or black residue on the walls. Anyone ever experience anything like that ?
MFWD
I've heard that, CO2 and also about the moisture, but the moisture and CO2 issue I don't think will be an issue for me. I would only use this heater as supplemental heat. Also, since I have a fireplace in the same area, I'm sure I get downdrafts of outside air when the fireplace isn't running.
I did purchase one last night. I have it partially installed. I needed a couple more gas fittings to finish the connections.
Hello,
MFWD
HAMM HD+120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+120I...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
