Flat face coupler
   / Flat face coupler #1
TheRealWorld
I have a gehl Track loader with the factory flat face connectors, I had a grapple connected and somehow damaged the female connector on the machine. I ordered a new one, got it, and put it on, but I can't get the hose in far enough to connect. The other hose connects no problem, I have not started the machine yet, so I should not have pressure there. Any idea if there is something I need to do when installing a new female coupler
   / Flat face coupler #2
Welcome to flat face connectors. My experience anyway.
Depending on how your aux circuit is controlled, you need to find a way to relieve the pressure, if that is the problem. I simply have a lever that always works but need to shut off the machine, then go one way and the other. Sometimes more than once. It can be difficult if electrically controlled. BOTH sides, the male and female have to have no pressure for them to mate. Maybe there is pressure on the grapple male.
I carry a torch in the winter, because if I didn't nothing about the FF connectors would work.
   / Flat face coupler #3
Check to make sure if there is a spot the yoke needs to be turned to line up with safety pins . Some have that as a safety so they can’t pop off.
   / Flat face coupler
I think there might be pressure on the male, so I will try to relieve it, I guess the way to do that might be to hook the two lines from the grapple together? Thanks for the help!
   / Flat face coupler
groundcover, thanks for the info, I will look it over, and see if I can see anything like that.
   / Flat face coupler #6
I still don't understand it. I THOUGHT the whole idea of the FF connectors was you could connect/disconnect them under pressure. Apparently, some, you can.
They do get damaged WAY too easy as well. Don't ever let a connector drop onto a hard surface.
When an attachment sits and gets hotter or colder, the pressure change can also cause problems. I found it best not to close the grapple all the way when putting it away.
   / Flat face coupler
I think this damage was the result of just being torqued many times and the grapple moves and twist around. I have actually built a support arm to strap the hoses to, so they did not have excess force on the connectors. I was right there, and I did not see anything hit it, but it came apart and started to shoot oil!
   / Flat face coupler #8
My experience is that NONE of them connect under pressure. They are a huge pain in the ***. I finally re-plumbed my excavator aux circuit with valves to the case drain so I can easily relieve pressure. I used to have to crack open a fitting on one of the hoses and dump out some fluid. After really releasing the pressure, they hook right up.
Another trick I came up with is to add a bleed port on implements. I just added a pressure gauge test port, then keep the mating fitting (without a gauge connected) in the cab. Just screw it on the test port and it pees out any excess pressure.
   / Flat face coupler
Good to know, I have several things to try in the morning now. I thought I must have needed to do something special, that was not obvious when I screwed the new on on.
   / Flat face coupler #10
I am told by a guy that deals in hydraulic fittings that there ARE ones that connect under pressure. Of course they cost more. I don't quite understand, as the oil has to be relieved somewhere. The real problem comes when you have a machine where you can't operate the circuit with it switched off. It bugs me, that although I can do this on my loader, I have stopped and restarted it hundreds of times, just to fiddle with these stupid connectors.
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
Duetz Power Unit (A50120)
Duetz Power Unit...
