Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #10,381
There are several ways of getting logs out of water, wait for low tide, use fishing pole, use row boat, put swimming trunks on and or offer a nickel to someone from NC and tell them it's a swimming pool..............
I致e not seen a pond with high and low tides, must only be in your neck of the woods I guess. People in NC like nickels?
   / Tractors and wood! Show your pics #10,382
On my mid size square tubing forks, 2x2" X 2-1/2'-ish long, I have 4 of them spaced equally-ish, then clamped a 1/4"x 4"x 5' flat bar across the front tips with 1/2" bolts, it keeps trees/logs going in-between forks. The flat bar has special fitted welded on pockets that fit the tips of all 4 forks.
Thanks Oldpath! that痴 just the type of idea I was wondering about. I値l try something on 2 forks before i invest in a 3-4th tine.
   / Tractors and wood! Show your pics #10,383
Welcome, sometimes one idea can lead to another idea or improve it. That might be one reason for some buying grapples but I cant afford it.........
   / Tractors and wood! Show your pics #10,384
OR you can do what I do...
IF, they are floating, I use one of these,
IF, they are sunk, I use one of these,
SR
Which leads me to a curious question, how long does it take for a log to sink and where did you get the tongs?
   / Tractors and wood! Show your pics #10,385
:thumbsup: Must be one reason why NC roads have clean ditches.......
   / Tractors and wood! Show your pics #10,386
The BIG pond in front of my house has high and low tides, a 16 foot difference. :D
   / Tractors and wood! Show your pics #10,387
Amazed me when I first experienced... water would be lapping at the dock and a few hours later the dock would be high and dry... and in 12-13 feet clear...
This is the same little inlet with salt water where some tall firs went down and took out the floating part of the dock... neighbor asked if I had plans and I didn't so he floated them to his place with the tide and used a block and tackle with his old truck to pull out sections... said it was a winters worth of clear Doug Fir... just the right size for his stove...
   / Tractors and wood! Show your pics #10,388
Your high tide is even greater than mine at your end of the bathtub. :laughing:
   / Tractors and wood! Show your pics #10,389
My ponds are not quite that big!! Heres one..
   / Tractors and wood! Show your pics #10,390
WHAT A STUD
Yep, that's what I need is some more 2x4 studs, so here is where I get them... not Lowes!
This is how "I" do it..
First cut a cant out of a log
Slice into slabs.
Stand those slabs up
Slice them up
And put on a skid, strap them own to keep them straight... mostly!;)
Tradewinds Power Unit (A50120)
Tradewinds Power...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
UNUSED LANDHONOR 4.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
