Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #10,381
There are several ways of getting logs out of water, wait for low tide, use fishing pole, use row boat, put swimming trunks on and or offer a nickel to someone from NC and tell them it's a swimming pool..............
I致e not seen a pond with high and low tides, must only be in your neck of the woods I guess. People in NC like nickels?
   / Tractors and wood! Show your pics #10,382
On my mid size square tubing forks, 2x2" X 2-1/2'-ish long, I have 4 of them spaced equally-ish, then clamped a 1/4"x 4"x 5' flat bar across the front tips with 1/2" bolts, it keeps trees/logs going in-between forks. The flat bar has special fitted welded on pockets that fit the tips of all 4 forks.
Thanks Oldpath! that痴 just the type of idea I was wondering about. I値l try something on 2 forks before i invest in a 3-4th tine.
   / Tractors and wood! Show your pics #10,383
Welcome, sometimes one idea can lead to another idea or improve it. That might be one reason for some buying grapples but I cant afford it.........
   / Tractors and wood! Show your pics #10,384
OR you can do what I do...
IF, they are floating, I use one of these,
IF, they are sunk, I use one of these,
SR
Which leads me to a curious question, how long does it take for a log to sink and where did you get the tongs?
   / Tractors and wood! Show your pics #10,385
:thumbsup: Must be one reason why NC roads have clean ditches.......
   / Tractors and wood! Show your pics #10,386
The BIG pond in front of my house has high and low tides, a 16 foot difference. :D
   / Tractors and wood! Show your pics #10,387
Amazed me when I first experienced... water would be lapping at the dock and a few hours later the dock would be high and dry... and in 12-13 feet clear...
This is the same little inlet with salt water where some tall firs went down and took out the floating part of the dock... neighbor asked if I had plans and I didn't so he floated them to his place with the tide and used a block and tackle with his old truck to pull out sections... said it was a winters worth of clear Doug Fir... just the right size for his stove...
   / Tractors and wood! Show your pics #10,388
Your high tide is even greater than mine at your end of the bathtub. :laughing:
   / Tractors and wood! Show your pics #10,389
My ponds are not quite that big!! Heres one..
   / Tractors and wood! Show your pics #10,390
WHAT A STUD
Yep, that's what I need is some more 2x4 studs, so here is where I get them... not Lowes!
This is how "I" do it..
First cut a cant out of a log
Slice into slabs.
Stand those slabs up
Slice them up
And put on a skid, strap them own to keep them straight... mostly!;)
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
