House Wiring (Romex) Push In Connectors
   / House Wiring (Romex) Push In Connectors #41
Nobody using this type of Wago?
   / House Wiring (Romex) Push In Connectors #42
I use those for stranded wire lights. The stranded wire that comes pre soldered you can usually get on the regular ones but for bare stranded those are a big help.
   / House Wiring (Romex) Push In Connectors #44
Never used wago brand. How tight does the lever lock wire...ie can it pop open in a Jamed up box
   / House Wiring (Romex) Push In Connectors #45
Well, no good licenced electrician I know uses the push in.
I also prefer to use the screw method and maretts for all my connections.
One thing I recommend is to occasionally re tighten all the screws in your main breaker box, especially the main entry fuse and knife switch ones as I have observed them loosen over time.
   / House Wiring (Romex) Push In Connectors #46
What method are they using to connect lights that come with small stranded wires to the larger solid wires? They’d probably much have to be soldered otherwise and that takes forever.
   / House Wiring (Romex) Push In Connectors #47
here in idaho every GOOD electrician I know ... and I’m an electrical contractor... uses them. Sometimes my wholesale house runs out of them
   / House Wiring (Romex) Push In Connectors #48
They are tight, and the lever is quit hard to open so it doesn't just realease, Wago is used all over here, quick and safe and does not have the problems screw terminals have.
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2002 Miller Trailblazer 301G Towable Welder Generator (A55851)
2002 Miller...
2014 PETERBILT 337 CHEMICAL TREATED TRUCK (A55745)
2014 PETERBILT 337...
