Dump Trailer Reservoir Rupture
   / Dump Trailer Reservoir Rupture #1
KY Gun Geek
Lexington, KY
JD 5105, JD 5055D, 2 JD 5085M's, JD 5085E, JD 5093E, JD 5115M
A little excitement at the farm yesterday-
A dump trailer we use to haul muck was being lowered after dumping a load when the bed suddenly dropped about 3 feet. Nice bang, and oil all over the place! I wasn't there so I don't have first hand observation of the failure. Person who was there says there's no more to know than bang and splash.
Preliminary inspection is that the plastic reservoir is ruptured - large split all the way down one side, and, of course oil all over the place in the pump box. I think reservoir is vented, so the build must have been very fast.
The "obvious" resolution is that I need a new reservoir (and believe it or not, the first answer I got from the manufacturers parts department).
However, I got to thinking about this, and I think there's more going on - like something else failed, causing pressure to build to high levels quickly in the reservoir, causing it to rupture. Feels to me like a check valve/flow control in the pump gave way. Could we have lost a seal in a cylinder that back-fed pressure (pressure from gravity on the bed) to the lift side of the pump? If this is true, a new reservoir will fail in a similar way.
These trailers are a little strange to me - they are pressure up, gravity down. But the pump controls the down speed and has to move fluid to fill the back side of the cylinder - the reservoir is engineered so that it does not hold lots of fluid, only the difference between one side of the cylinder and the other (the rod).
Parts guy is doing some investigation, but I thought I would run this by the forum.
The trailer is a Gatormade, 16'. I can't find any manufacturers labels on the pump/reservoir. Best I have is a sticker that says WX-1788. This returns hits on hydraulic pumps when googled, but nothing clearly marked with a manufacturer, manual, etc. and no posts of videos about this being a known issue and what the fix is.
Thanks for your help!
   / Dump Trailer Reservoir Rupture #2
I don't know much about much....but...
I think you're definitely right to be concerned that the ruptured reservoir is a symptom, not the real problem.
If it's "gravity down" is there really fluid on the back side of the cylinder or just vented? How many hydraulics lines go to cylinder?
If just one, I'd guess cylinder is ok, but whatever restricts flow to reservoir or a valve that is suppose to block pump pressure to reservoir has failed.
If it is a double acting (2 hose connections) cylinder, (not strictly gravity down), then maybe losing a seal in cylinder could pressurize tank....but I don't fully understand how.
:2cents:
   / Dump Trailer Reservoir Rupture #3
Long shot, but could someone have filled the reservoir while the cylinder was extended since "It was low on oil." ?
   / Dump Trailer Reservoir Rupture #4
If it's a power down trailer, an overflowing tank is usually caused by a low battery. The power down function partially fails due to low battery but the bed continues to lower by gravity, which forces fluid one way out of the cylinder and overflowing the tank. I could see that putting pressure on a tank if it can't vent fluid out fast enough.
   / Dump Trailer Reservoir Rupture #5
that's a good lesson on why to never trust your life on hydraulics!. yes, something failed that let the fluid come rushing into the reservoir, that's why it came down so fast..
   / Dump Trailer Reservoir Rupture #6
I struggle to see how the tank has anything to do with the bed dropping 3ft. That plastic reservoir tank isn't what holds the bed up.....
As Coby eluded to, the tank rupture is the effect, cause hasn't been determined yet.
   / Dump Trailer Reservoir Rupture #7
Seems reasonable.
So you’re saying pump doesn’t pump (and extract oil from tank giving room for incoming oil) yet the solenoid valve allowing oil to/from cylinder still functions? This lets gravity be the driving force that pressurizes the the loop at the lift side of the cylinder instead of the pump. And first thing pressure hits is reserve tank.
I’ll buy that for a nickel.
I’m curious, would a low pressure relief valve on the return line that’s piped to output of pump only opens in this scenario? Be a solution?
Also a bigger (working?) vent in reserve tank or being quicker on the buttons might of helped.
   / Dump Trailer Reservoir Rupture #8
I contend the tank ruptured because it filled faster than it could vent. This was caused by cylinder or check valve failure that allowed the bed to instantly drop 3ft and overrun the tank.
   / Dump Trailer Reservoir Rupture #9
Was the trailer overloaded so it struggled lifting, then the operator hit the down button? High pressure forced back to the reservoir?
   / Dump Trailer Reservoir Rupture #10
Seems reasonable.
All I know is a low battery is the common cause. I've read it can be due to the pump not keeping and the free fall overloads the tank. I grabbed this from another site from someone who worked on them: "When the battery is low it will not open the solenoid valve to allow fluid back into the top of the cylinder. The cylinder has fluid on both sides of the ram. When you lift the dump bed up the pump moves fluid to the bottom of the ram, pushing fluid out the top side of the ram. When you lower the fluid is released by a valve on the bottom of the ram and pushes fluid out the bottom. What happens is the valve that allows fluid back to the top does not open and the fluid pushed out the bottom goes into the tank overfilling it."
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
New Long Forks (A53002)
New Long Forks...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
