Heating. Propane vs Electric vs Wood Pellet
   / Heating. Propane vs Electric vs Wood Pellet #11
I installed a Mr Cool DIY minisplit this summer...we use it exclusively for A/C in the summer (heat the entire house and garage with an Outdoor Wood Boiler in winter) but I did kick the heat on a handful of times in the fall before my boiler was going - worked really well. As stated they arent as effective in very cold temps which are routine here...but in TX I imagine even in your coldest days it would work fine.
Very reasonably priced and install was relatively simple - Im very happy with mine so far!
Awesome. Thank you.
   / Heating. Propane vs Electric vs Wood Pellet #13
Depending on priority and or comfort,none electric infrared propane heaters may be an option.
   / Heating. Propane vs Electric vs Wood Pellet #14
I need some advice. I am currently building my bard /shop. The main shop will be 30 x 40 fully spray foam insulated. What is my best option for heating it? Should i go electric, propane, or wood pellet stove? What are the pro's and con's that you have experienced. Which would be the most long term economical option? Everything that i have been reading about Pellet stoves is positive. They say that with the cost difference in fuel, IE: Electric vs Propane vs pellet costs, that you will pay for the cost of your Pellet Stove within two years. (since wood pellets are so much cheaper).
I need advice so i dont regret a decision later.
Most economic and energy efficient would be electric with geothermal. Best warmth with pretty good efficiency would be wood pellet. Lazy man's warmth but energy turd would be propane; also rather a safety hazard.
Ralph
   / Heating. Propane vs Electric vs Wood Pellet #15
A
Ralph
Go ahead and pencil out geothermal for a 30x40 shop. Get back to us.
   / Heating. Propane vs Electric vs Wood Pellet #16
2 questions ovrsd, what does it cost you to heat your shop, and when you measure plow bolts do you measure overall length? I need to replace the bolts that fasten the mouldboard on my back blade.
As Rick stated, overall length of the bolt. Here's a 2 1/4" bolt.
As to shop heat. I can't give you an accurate answer. My house shares the propane tank. I've used 285 gallons of propane since 20 August. That's heating both structures and heating our domestic water.
I started heating the shop late last Winter. It alone burned 320 gallons of propane from 3 February to 20 August.
I'm going to guesstimate that I'll burn 1200 gallons per year for both structures. I'm paying $1.44 for propane. I'll be able to give a better answer next Summer.
   / Heating. Propane vs Electric vs Wood Pellet #17
   / Heating. Propane vs Electric vs Wood Pellet #18
   / Heating. Propane vs Electric vs Wood Pellet #19
A
Less cost but almost as efficient are the ductless (some call them mini splits) heat pump units. Got a couple inside units here in the basement operating off one outside Fujitsu unit. Would be about the quietest, equaling propane fuel burning.
Ralph
   / Heating. Propane vs Electric vs Wood Pellet #20
Ralph
Hey, I resemble that remark!!! :)
I'm pretty sure I can heat my shop cheaper with propane than I could have with wood. Even if wood is slightly cheaper, I have better things to do with my time.
Edit: Please explain the safety hazard of Propane versus a pellet stove?
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2025 JOHN DEERE X350 LOT IDENTIFIER 153 (A53084)
2025 JOHN DEERE...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
