Oil & Fuel Home heating fuel in a tractor?
   / Oil & Fuel Home heating fuel in a tractor? #1
BX23S-1
No Clue
Kubota BX23S
moship asked for a new thread, so lets go folks! I`m guessing he dint like that other 16yr old thread coming back to life ;)
Ok so i`ll start... who`s burnin that house oil in their diesel tractors!!! Come on, FESS UP!!! :laughing:
   / Oil & Fuel Home heating fuel in a tractor? #2
How about a curve ball here?
I've wondered what they use for fuel in Alaska?
Think Ice Road Truckers.
I'm thinking #1 with lubricity additives.
Or jet fuel?
Or jet fuel?
I dont know for sure, but i have a couple friends that live in Nome Alaska. Seems i`ve heard them talk about a 50/50 mix of diesel and kerosene and a ton of fuel additives. Sometimes they dont even shut their diesels off for days.
   / Oil & Fuel Home heating fuel in a tractor? #4
I remember posting in that old thread, somewhat the same info.
Except for the die added to heating diesel; it and motor diesel are the same product. My BIL mega farmer in OR bought heating fuel for his house and barn and used it in his tractors and trucks. He had 1000 GL tank and had a pumped underground lines to his furnaces. Buying that qty in heating fuel save him a lot of money.
A thing to remember is that the lower (thinner) you get in the distillate chain the lower the BTU content (cetane rating), hence the lower the power output of a given engine. Back in the old days it was not uncommon to use #3 diesel in engines, especially marine, farming, and stationary plants. Not sure it is even made today. It was a dark amber color from the higher carbon content. #4, 5, 6 and bunker fuel had to be heated to thin it out for the injectors. #6 and bunker fuel in effect were asphalt. The residue after refining the thinner oils out of the crude. #3 was also the common heating fuel back in those days where it is now low sulfur #2.
Stationary diesels almost always used #3. That was before low sulfur took over. The power increase was considerable. The large diesel engine ships still use #6. It is heated if I trust my memory to 250 degres C. Then centrifuged and strained to remove water and solids. I have seen those engines with pistons 10' in diameter. With today's environmental hue and cry that may have given way also #2.
During the Vietnam era the military had multi fuel engines in trucks so fuels found locally or when #2 was not available. Not unusual to use jet fuel. The manuals gave you the ratios of motor oil to add to provide lubricity for various higher distillated fuels. A loaded 5 ton truck on jet fuel had a lot less power, difficult to pull much of a grade.
With today's additives, resorting to kerosene may not be indicated except in temps well below 0 F. We Seabees were specially trained in all this stuff when we were the designated cold weather Battalion. The Navy had arctic fuels and lubricants in storage for such contingencies. Almost 60 years now so memory is getting short.
Ron
Ron
Great wealth of information Ron! Glad you posted it, couple things i didnt know, and now i do. Thank you!
   / Oil & Fuel Home heating fuel in a tractor? #6
THANKS!!! :thumbsup:
   / Oil & Fuel Home heating fuel in a tractor? #7
If you are using "off road" dyed fuel you are it is the same.
   / Oil & Fuel Home heating fuel in a tractor? #8
I use off-road dyed fuel to save from paying the very high PA fuel tax.
Transport in 5 gallon plastic jugs.
Use Sta-Bil Biocide and either Stanadye or Power Service to for lubrication/cetane/water always
Filter fuel as it is going into tractor.
Clean fuel jugs after ever use and let air dry. (I've seen crude grow in the small amount left behind.)
Try to keep tractor full after every use.
Pretty much the same here. Now that i`ve learned why i need to use biocide, that just got added to the list of my additives.
And yeahhhhh, holy cow man, you guys fuel tax went out of sight!!! I`m on the border of PA, we use to go there to fill up all the time because NY prices were to high. Now your prices went passed us in NY.
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
