Couple Noob Trailer Questions.....
   / Couple Noob Trailer Questions..... #1
gltrap54
Topeka,KS
B3200 Kubota
Recently bought this older T10D-16' Towmaster that's in need of some deck work.... Existing deck is 2" white oak.... Where's the best place to buy replacement boards? If I was to buy them from a local saw mill, would they need to be treated?
In terms of overall quality, where does Towmaster trailers rank?
   / Couple Noob Trailer Questions..... #2
If you want the same material as on there now,ask for #2 yellow pine;) and it will benefit immensely if pressure treated.
   / Couple Noob Trailer Questions..... #3
+1 That looks like good old spruce/pine/fir lumber.
   / Couple Noob Trailer Questions..... #4
That looks like oak to me. You could source oak from a mill or just go with PT SYP. No idea on the quality of tow master
   / Couple Noob Trailer Questions..... #6
I disagree!
That original decking is NOT OAK!
   / Couple Noob Trailer Questions..... #7
I disagree!
There’s a piece of plywood patching the deck. I’m pretty sure the rest of the deck is pine.
   / Couple Noob Trailer Questions..... #8
There is pine, oak and plywood on the deck in the picture. I would go back with ground contact pressure treated pine.
   / Couple Noob Trailer Questions..... #9
   / Couple Noob Trailer Questions..... #10
replaced mine with pressure treated pine. Menards had the best lumber for it around here without costing more than the trailer itself. tear old off and cut off the screws if they wont come out. clean it up and paint the cross members. use 1/4 or 3/8 self tapping screws. drill the appropriate size hole in the wood and metal, run the screws in by hand, i used a brace, to avoid breaking them or stripping them out or over driving them.
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
