Running used steer tires on a heavy truck. Bad idea??
   / Running used steer tires on a heavy truck. Bad idea?? #11
The tires have a manufactured date stamped in too. I'd check them, and if made within the last 10 years or so, run 'em. If the size is different, I'd swap the pair.
That’s what I planned on doing. It won’t make a bit of difference with the steer tires being a tad bigger than the rears. Putting one on the duels wouldn’t work.
   / Running used steer tires on a heavy truck. Bad idea?? #13
Actually it would work for an empty truck that's just being driven to see if the tires are sound. If one blows, the inside will get you limp home. And, the load condition with still warm up the carcass enough for the evaluation. If it works the change-over will be the easiest procedure.
2013 PETERBILT 367 (A55745)
2013 PETERBILT 367...
2018 KENWORTH T800 DAYCAB (A55745)
2018 KENWORTH T800...
2006 INTERNATIONAL 9400I DAYCAB (A55745)
2006 INTERNATIONAL...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A56138)
2014 CHEVROLET...
