Running used steer tires on a heavy truck. Bad idea??
   / Running used steer tires on a heavy truck. Bad idea?? #11
The tires have a manufactured date stamped in too. I'd check them, and if made within the last 10 years or so, run 'em. If the size is different, I'd swap the pair.
That’s what I planned on doing. It won’t make a bit of difference with the steer tires being a tad bigger than the rears. Putting one on the duels wouldn’t work.
   / Running used steer tires on a heavy truck. Bad idea?? #13
Actually it would work for an empty truck that's just being driven to see if the tires are sound. If one blows, the inside will get you limp home. And, the load condition with still warm up the carcass enough for the evaluation. If it works the change-over will be the easiest procedure.
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55302)
2025 Mahindra 6075...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
New/Unused CFG Industrial H15R Mini Excavator (A54865)
New/Unused CFG...
