Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,481
Have two computers, both see the download slower than the upload.
What is a wired test?
I guess my ISP is AT&T since the signal to the mobley is from their cell tower:
Yeah have very seldom seen Upload faster than download on the Mobley
Download speeds lately have been pretty good
Upload speeds lately around 5 Mbps Up and around 30 Mbps down
Your Test Results (Tested on 12/16/2019, 8:20:14 PM)
Download Speed HELP 31.1 Mbps (3887.5 KB/sec transfer rate)
Upload Speed HELP 5.11 Mbps (638.8 KB/sec transfer rate)
Latency HELP 64 ms
ps. did see that effect with the Mobley in some different locations and orientations
Try moving the Mobley and re running the speed test
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,482
Never seen that here. Just ran at Speedtest.net and got 17.37 down and .57 up. Ran it again at AT&T and got 20 down and .7 up.
My Mobley died right out of warranty so I have it's sim in a ZTE Velocity.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,483
I'm seeing at times upload speeds being are the download speeds to
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,484
I tried a Nighthawk, and my speed went down by alot. I went outside with it and moved around to see if i could get better, but couldn't. I admit to be pretty surprised, i thought it would be much better.
Before the Nighthawk I tried a Unite Explore. That one was similarly problematic and got me lower speeds than the Mobley. I guess it depends on your tower situation which tech works best.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,485
Yep, I know from previous experience is is very location and position sensitive. We are just over 5 miles from the cell tower. The two computers are at opposite ends of the house. The Mobley is between them hooked to a small 12 volt AGM battery with a Schumacher SC1299 Battery Maintainer on it.
The problem is positioning the Mobley so both computers get a fast download speed. I turned it and moved it back a little and got this on mine:
____________________________________________________________________________
With this signal to the Mobley:
________________________________________________________________________________
Got 8.1 down and 12 Mbps up on the wife's computer, so will leave it there.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,486
I wish I had a decent upload speed.
I have my unit attached inside the blinds in my computer room with some loosely connected zip ties. I can slide it off and on the blinds pretty easy. This is the best location I've found in my house. I think the AT&T tower is about 10 miles away.
I recently switched my phone to AT&T prepaid from Verizon. My call quality started to decline and I started getting popup messages on the phone to try wi-fi calling for improved in home connections. Sounded like Verizon made some changes that they KNEW would effect in home service and thought I should make changes to accommodate them. Seeing as how my wi-fi was on AT&T I felt the change was a logical step to improvement and so far it has been.
Previously when my AT&T connection would be out or suffering I would use my Verizon phone for wi-fi. It would never get much over 750 kbps down.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,487
Got this this morning, first time in all the many years that I have been running speed tests that the down and up speeds were the same:
__________________________________________________________________________________
Just now checked the wife's computer, got 8.5 Mbps down and 6.9 Mbps up.
Signal strength on the Mobley from tower is -111 dBm
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,488
This is the first I've noticed the more info option on the fast test. Interesting the different locations referenced.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,489
And note the major differences in the down and up numbers in the bottom line. Mine are opposite of your's. Your down is faster than your up. Which is how it should be.
The different locations are from the AT&T IP Address shown. Mine has always shown the Dallas TX area, really messes up google search location results.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,490
The numbers in the bottom line (30MB and 3.9MB) are not speeds, they are the size of the test load. Netflix (fast.com) recently added that bottom section, which you can see if you click the new 'More Information" button at the bottom of the initial screen. If these numbers are not what you were referring to then disregard this...
Speaking of location, it sounds like your IP is tagged as being from AT&T's network in the Dallas area. I have a similar problem where the IP I get from either my phones or the connected car hotspot is shown as being in Chicago. I'm in central MN. This definitely screws up location-based stuff like web sites trying to figure out what is the closest store to me. Wish I could resolve that. I contacted AT&T about it several years ago and they responded to me like I had three heads and was asking what color the cheese on the moon is. Eventually they just said "that shouldn't happen... don't know."
Rob
KBH Tank Trailer (A56436)
KBH Tank Trailer...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
