CBD/hemp oil, anybody use it?
   / CBD/hemp oil, anybody use it? #81
I'd be afraid that it would get too mellow and not get any work done, instead just sit around eatting up all of your Oreos and Doritos.
:thumbsup: . . . yep thank God I don't do Oreos or Doritos. Cheetos yes :)
   / CBD/hemp oil, anybody use it? #84
You sure did, Jstpssng. Feds only enforce that on federal lands, anyways. So kids, no smot poking in national park or military bases. :D
   / CBD/hemp oil, anybody use it? #85
Myth busters proved that poppie seeds will give you a false positive on a drug test as well. He did have to eat a butt load of them though.
A bunch . . . :eek:
Buttload: a Butt is a traditional unit of volume used for wines and other alcoholic beverages. A butt is generally defined to be two hogsheads, but the size of hogsheads varies according to the contents. In the United States a hogshead is typically 63 gallons and a butt is 126 gallons.
Assload: an arss load is derived from the amount of weight that can be held carried by a mature, healthy donkey (arss).
   / CBD/hemp oil, anybody use it? #86
Thanks. I did not know this.
   / CBD/hemp oil, anybody use it? #87
And you can measure how many rods to a hogshead your tractor gets....
   / CBD/hemp oil, anybody use it? #89
Ok, how about "metric sh*t ton", where's that from? :D
   / CBD/hemp oil, anybody use it? #90
Today when getting some hay from storage and putting it in the tack room/feed room I got my elbow inflamed again. I took CBD oil under my tongue and CBD ointment directly and about 20 minutes later it dulled down the grabbing/stabbing pain so I could continuing doing what I needed to get done.
Inside Look: Hemp Extract and the Microbiome - Hyperbiotics
While I do not tell others how to treat themselves I have studied how CBD oil works and I know it has helped me going on a year now.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2022 MDB Green Climber LV600 Plus Mulcher (RIDE AND DRIVE) (REMOTE) (A50775)
2022 MDB Green...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55302)
GMC 3500 Extended...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
