Splitters and Wood, show your pics!
   / Splitters and Wood, show your pics! #51
I still like to get a load of big rounds when ever I can,
BUT, as I get older I find myself preferring to have big rounds ripped in half,
or even into quarters,
It just makes them so much easier to handle on the splitter, but those big rounds and a good 4-way, sure turn out a LOT of splits fast!!
Ya just gotta LOVE a diesel engine humming away sloooowly sipping fuel at 1400 rpms, running a good splitter with a 4-way, instead of a screaming little motor right next to you!
SR
   / Splitters and Wood, show your pics! #52
Ya just gotta LOVE a diesel engine humming away sloooowly sipping fuel at 1400 rpms, running a good splitter ..., instead of a screaming little motor right next to you!
I use a set of 20'+ hoses with QDs...I can use either of my tractors and point the exhaust downwind etc...
I finally added a lift...
   / Splitters and Wood, show your pics! #53
I too prefer big rounds. That would probably be a different story with out a FEL and my Splitfire 225 splitter with a log lifter.
It seems everyone wants the 12" or below diameter wood for their burning. If you can get away with it, great. Ever since I bought this Timber Wolf splitter, I'll take the big trunk that nobody wants. It is a lot more challenging to get this split to size, but it does produce a large amount of wood in a short time.
   / Splitters and Wood, show your pics! #55
^^^ very nice. Is the plastic UV resistant?
Yes the plastic bin is UV resistant. I will likely paint them in camo so they look better and that should help with UV as well. The plastic "pallet" bottoms on the totes are nice as they will not rot.
I was using wood pallets as they were free but the totes offer many advantages for my use. Scrounging "free" pallets that were about the same size and in decent shape got be a challenge and I live 25 miles from town. Then I needed to modify them to hold wood properly and put a cover on them to shed water and snow. The totes are not "cheap" but not expensive either. I will never need to purchase anything else. The wood pallets lasted 3-4 years before needing repair/replacement.
   / Splitters and Wood, show your pics! #56
Wood split from big rounds also dries faster since 3 or 4 sides of every piece is a split edge without bark holding moisture in. Bark is a moisture barrier. Also, it is cleaner wood when you bring it into the house without insects under the bark.
   / Splitters and Wood, show your pics! #57
I mostly get my big rounds from logs that are too low quality to be saw logs, here's a prime example,
The tree was tornado damaged, but I did get a 7' saw log out of the upper part. Anyway, once cut out, I skidded it to an opening,
I then cut it from one side on the ground, then lifting it up onto my wagon,
and finished cutting it there, from the other side. That one log made a nice load of big rounds,
SR
   / Splitters and Wood, show your pics! #58
Good deal Rob . . . nice.
   / Splitters and Wood, show your pics! #59
SR
Was that an acorn tree- ER, an oak? How many years will you let that one dry?
   / Splitters and Wood, show your pics! #60
SR
I lost hold of a large round on my TW-5 and luckily when it came off the splitter it got me and not my son. Frozen hard maple
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
