13 year old tires, time to replace?
   / 13 year old tires, time to replace? #51
:stirthepot::stirthepot::stirthepot::stirthepot:
Just trying to see what kind of a response I would get.
Now I’ve got to go order tires.
COSTCO often has good tire pricing.
   / 13 year old tires, time to replace? #52
I guess all the hyd. hoses on my trencher need replaced. They are well over 20 years use. So I need to replace the seat also? What about a 1965 Case 730? If a tires gives up while haying will I scare a neighbor, or frighten a cow?
I better check with my ins. agent. Sounds like ALL my equipment will need to be scrapped. Sure don't want to sell it at an auction and be liable for something!
   / 13 year old tires, time to replace? #54
The thing about a hydro hose is, that of it pops a leak on a high pressure side, and a person is in the wrong place, injury could happen from being sprayed.
Probably about as likely as having a blow out on a high speed excavator track tho.....
:laughing:
   / 13 year old tires, time to replace? #56
   / 13 year old tires, time to replace? #57
I have a JD Model N manure spreader, '60s origin best I can tell, with the original tires still intact, still holding air such that I don't have to air them back up to use it annually, weather cracked like you never saw a tire weather cracked. Totally amazing, but they are not overworked either by the weight they have to carry, or the friction they have to produce to roll the scraper bars along the bottom of the unit.
   / 13 year old tires, time to replace? #58
Tube them
   / 13 year old tires, time to replace? #60
Might put some good tire sealant in them and run them until they pop.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
Hyster H225E (A47384)
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
