Kitchen & Pocket Knife Sharpening, what do you use?
   / Kitchen & Pocket Knife Sharpening, what do you use? #11
Three or four different things: 1) electric one with 4 spots to slide the blade through; 2) a carbide or diamond hand held where you slide it over the blade or the blade through it; 3) some old stones inherited from my wife's father; 4) a circular electric grinder (only used for bad stuff). For kitchen knives downstairs, it's mostly #1 because that's where it is. In the main floor kitchen, it's mostly #2. Use #3 and #4 for other knives and cutters.
Ralph
   / Kitchen & Pocket Knife Sharpening, what do you use? #12
Question. How do you sharpen ceramic knives, I don't have any but curious as I believe they are deadly sharp.
   / Kitchen & Pocket Knife Sharpening, what do you use? #13
I keep this in the kitchen for bringing a knife edge almost back to good and sharp - Accusharp https://www.amazon.com/dp/B006PTLPC2/ref=dp_cerb_1
Then about once a year, all the knives get sharpened with a whetstone.
All of my kitchen knives are carbon steel - I hate stainless steel blades
I used to get fancy with whetstones, etc, then saw this device rated #1 by on America's Test Kitchen on TV (PBS) one time. They tend to be real clever/frugal about their testing and recommendations (like farmers) and had no problem recommending a low cost hardware store sharpener over fancier and more expensive products. It's been working great for us for many years.
   / Kitchen & Pocket Knife Sharpening, what do you use? #14
Over the years I have found that certain knives require the use of certain stones. I have knives that will take a razor edge with a whetstone, and a ceramic stone will take the edge right off. Or stainless knives that will only work with a ceramic stone and whetstone destroys the edge. If I go through the kitchen and pull all the knives out I would need about 6 different stone to make it all work.
   / Kitchen & Pocket Knife Sharpening, what do you use? #15
I use a Lansky stone kit. Works on just about any kind of knife I've got around here. We don't have any ceramic ones, but I've looked at them a couple of times. It's my understanding that they don't need sharpening? But also that they are extremely brittle and easily broken. Takes a different method of use to always be cognizant to not flex or torque the blade in any way.
   / Kitchen & Pocket Knife Sharpening, what do you use? #16
I also use the Accusharp tool. Works great. Fast, easy, sharp. Cheap. When a blade does not respond to that, I shape it up on a 2" belt grinder.
   / Kitchen & Pocket Knife Sharpening, what do you use? #17
I use a good old fashioned oilstone with a drop of oil.
One lives in the kitchen and its brother in my shop.
A couple of passes and I can shave!
For correcting a blade I do have a diamond blade kit but always finish up with the oil whetstone.
Those whetstones are getting harder to find but worth every $ IMHO!
Probably Lee Valley or other specialty woodworking supply houses.
   / Kitchen & Pocket Knife Sharpening, what do you use? #18
Curious what everyone is using to sharpen their kitchen and pocket knives.
I use a Smiths Diamond edge pro knife and sissor electric sharpener . . . and then with my pocket knife I'll finish it up on a old flat stone, with a little spit or 3-1 oil.
   / Kitchen & Pocket Knife Sharpening, what do you use? #19
A diamond sharpener that has a couple of rollers to align the blade, drag through about 3 times, 2 pads, start coarse then fine, when they get a bit sad time for Mr Tormek to make an appearance (mine is a clone by Record), spend about an hour doing the lot probably twice a year.
Knives are mainly F Dick which are carbon steel but SWMBO has some SS, they are useless and won't hold an edge.
I have and old set of Henckel knives that are SS and hold an edge like a surgeon's scalpel.
   / Kitchen & Pocket Knife Sharpening, what do you use? #20
Because I'm basically cheap and I like HF stuff, I use the Gordon ceramic rod sharpener (2 bucks) followed by my leather strop I use on my straight razor.
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
1839 (A51248)
1839 (A51248)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2018 Generac S/A Towable Light Tower (A52377)
2018 Generac S/A...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
