Recommendations for tractor hauling company
   / Recommendations for tractor hauling company #1
terencedsprague
ford 1520
I need to haul a 2200 lb tractor - Ford 1520 from Akron OH to Fenton MI. Any recommendations on a reputable company I can hire to do this?
Thanks!
   / Recommendations for tractor hauling company #2
Thanks!
228 miles, and 2,200 lbs.?
That should easily work with a U-Haul trailer
   / Recommendations for tractor hauling company #5
A reputable company will have a DOT #, MC # (Authority), DOT inspected vehicles, and depending on the truck and/or trailer used, a Medical Card. They will also have to have a $750,000 liability insurance policy, among other requirements, determined by equipment.
On UShip, you’ll find a lot of fly-by-nighters. Same with Facebook and Craigslist. They will generally tell you they are “licensed and insured”. Ask what that means. They usually won’t know. When you get their DOT #, look it up, you will be able to see their driving/inspection history and if they actually have the Authority.
If they tell you they don’t need any of this, they are lying or ignorant, either way, not who I want hauling my stuff. If their weight rating is over 10,000 pounds, they have to have all this (not a CDL or Medical Card, if at 26,000 pounds or less).
On UShip, you値l find a lot of fly-by-nighters. Same with Facebook and Craigslist. They will generally tell you they are 斗icensed and insured? Ask what that means. They usually won稚 know. When you get their DOT #, look it up, you will be able to see their driving/inspection history and if they actually have the Authority.
If they tell you they don稚 need any of this, they are lying or ignorant, either way, not who I want hauling my stuff. If their weight rating is over 10,000 pounds, they have to have all this (not a CDL or Medical Card, if at 26,000 pounds or less).
Thanks so much, very good information!
   / Recommendations for tractor hauling company #7
I think hot shot stuff is generally $1.50-2.00 per loaded mile these days. That's probably for a bit longer range stuff, I'd guess a bit more overhead for shorter trips. The previous stuff about DOT numbers & insurance is good. A 1 ton pickup truck may or may not require a CDL, depending on the GVWR of the trailer.
   / Recommendations for tractor hauling company #8
Yes, should have mentioned: Anyone charging less than $1.00 per mile is not making money or cutting corners somewhere (a few are just really bad at math). The $1.50-$2.00 per loaded mile would be a reasonable starting point.
   / Recommendations for tractor hauling company #9
I do, I'm over 20K GCVW, so DOT numbers required. It's not the GVWR of the trailer, it's the total GCVW that determines if you need DOT numbers. 20 is the magic number here in Michigan.
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2011 KALMAR 4X2 YARD MULE (A55745)
2011 KALMAR 4X2...
