Safety switches, or lack thereof
   / Safety switches, or lack thereof #11
MY MF GC 1715 has seat safety switch and only kills motor when I leave seat and HST is still in gear..... Biggest pain for me is bumping any lever and engaging something like mid mount PTO lever and its out of neutral position and machine won't start (mid mount PTO has no implement attached and is never used), I have to go over all the lever to ensure all are correctly in neutral) probably need "position locks" for unused levers ... It's a learned procedure like when stopping to get off tractor or shifting into neutral ALWAYS set brake first... When HST in neutral you have no (trans/engine) braking or control you normally have through HST... Something it can be a bit startling...
Conversely when I bought my property there was a JD L120 riding mower mixed in deal... It has seat safety switch disabled and reverse lockout/bypass switch wired around so it would mow in reverse without having to hold down push button...
Lockout can be good or bad but one should try to work with them if possible ...
The real enemy here is lawyers and litigation, that is why manufacturers try to make machines "idiot" proof, much to consternation for educated/intelligent users...
Dale
   / Safety switches, or lack thereof #12
just imagine what happens when you fall off the seat while the tractor is moving!. and don't say it can't happen!. incidents of that is why safety's are put on in the first place!..
   / Safety switches, or lack thereof #13
ONLY SAFETY SWITCH I'VE RUN INTO ON MY 4110 IS CLUTCH MUST BE IN TO START. I HATE SEAT SWITCHES. FIRST THING I DO IS GET RID OF THEM. I RAN HEAVY EQUIP FOR A LIVING. MY CRAFTSMAN LAWN MOWER --MUST TURN KEY BACK ONE NOTCH TO MOW BACKWARDS. ONE TURN AND RUN ALL DAY.
   / Safety switches, or lack thereof #14
And then there is the seat belt on my tractor that gets tighter across the hips every time the seat bounces (downward) and belt tensioner locks it tighter with ever bounce....
Dale
   / Safety switches, or lack thereof #15
levi333 My CK2610HST is a 2019 with no seat switch. Maybe my dealer did me a favor
   / Safety switches, or lack thereof #16
Thats what seat belts are for!
If you fall off with any significant tractor speed, it would still run you over, even if you had a switch.
Shorted mine on my Massey the first week I had it. Engine would cut out and back in every time I drove over rough ground. If I remember right I couldnt use my chipper either.
   / Safety switches, or lack thereof #17
I like safety equipment. I'm happy they catch brainfart errors, which seem to get more common as the decades creep by.
Even so, my 2018 NH WM25 seat switch is much too touchy. Several times I've killed the engine with it because I was reaching for a control or trying to see. Usually this happens when there's an audience, like when I'm blocking a car in the driveway and trying to get out of the way, or working with a helper.
I *ALWAYS* wear my seat belt, even just to pull the tractor out of the barn (in fact I remember reading some horror story about somebody catching some high tractor structure on some low barn structure and slowly flipping the tractor just pulling out). I think any seat switch that will kill the engine when you shift around inside the seat belt is too **** sensitive, and I think I'm going to disable it. Even though I'd actually prefer having a seat switch, as long as I could shift around in the seat with the seat belt fastened.
   / Safety switches, or lack thereof #18
Well at least the CUB "dance" you do once per cutting cycle. How hard is it to turn the key back a notch and press a button? Once. Husqvarna much the same. Disconnecting the MIR switch is as easy as pie should you see the need. How ever nice Deere L&G tractors are, they make you think to push a button each time you reverse w/ the PTO on rather than concentrating on what you are doing. DO I look forward to push a button 20 times when I cut the lawn or do I look backward in the direction of travel. Seems sdrawkcab to me. Seat switches can save or life and limbs on a rider mower. Knew someone who got comfortable with hopping off when the blades were turning and off the end of her toes went!
   / Safety switches, or lack thereof #19
Some are good. We had a 1983 Benz that had almost none. Had a switch on the clutch and the brake for when the cruise control was on. Both shut it down. That was it. Could actually start the car in gear, and it would likely start, too.
I'm surprised that the Kioti has none. Makers went too far with the under belly mower switches.
Ralph
   / Safety switches, or lack thereof #20
I've got my flameproof suit on so here goes...I bypass the seat switch, the backup interlocks all that jazz with the exception of the neutral safety switch. I was taught how to operate equipment at a very early age and if safety is second nature, you don't need all that stuff. Let the flaming begin!!
And I don't care about lawsuits, liability, resale value or "climate change."
You said it all right there.. I can稚 tell you how many times I致e fixed ignition issues by unhooking those things on my stuff. Now I知 preemptive and off they go straight away. There are decent applicable safety devices but those aren稚 one.
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2017 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2017 KOMATSU...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
