Ford NH 1925 air in hydraulics
   / Ford NH 1925 air in hydraulics #1
namvet69
Member
3910 Ford, 1925 New Holland, John Deere 990
Hey guys, I changed the hydraulic oil and filter on my 1929 hydro and now it has air in it. Bucket jerks up and down, same on 3 point. Tranny is hard to get moving and makes a funny vibrating noise when I take off forward. Any help is appreciated, never had this happen before. There is no oil leaks but seems like it's sucking air between the pump and filter housing. I put a new O ring in the tube at the filter housing, didn't help.
   / Ford NH 1925 air in hydraulics #2
Was the new filter matched up with the old one gasket size , Old gasket removed from housing , Did you cross thread the new filter on , Is the hydraulic oil full
   / Ford NH 1925 air in hydraulics #3
If you have no air leaks on the suction side you should be able to cycle the bucket up and down a few times to get the air out. If that won't do it you may have air getting into the system.
Everything checked out good. I'm thinking it is sucking air somewhere between the filter and pump. Checked and tightened the T hose. Funny thing is it was fine until I changed the oil and filter.
The gasket from the old filter stuck to the filter head?
No, checked that out. Also put new O ring in filter housing for suction pipe.
   / Ford NH 1925 air in hydraulics #7
How do you know it's sucking air? What kind of hydraulic oil did you use? Strange it worked till you changed it.
It's strange but I pulled the T hose last night and noticed it was a little soft on the filter pipe side. Gonna order another one and see if it takes care of the problem. And to answer your question, you can actually see the air bubbles in the oil after you shut it off. I use the same oil, 134D.
   / Ford NH 1925 air in hydraulics #9
Just wondering if you found the source of air?
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2006 MACK CV713 KILL TRUCK AND TRAILER (A52472)
2006 MACK CV713...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
