nolan3387
So to start off, my sector shaft broke a few weeks ago. I ordered a new one and replaced through the side cover on the steering box. While I was replacing, I realized the worm gear nut was not moving with the steering wheel. Further investigation revealed the bearing cage on the back was broken off, so the wheel just spun without the nut going up and down. I found a bearing cage/bearing replacement kit online. I am in the process of trying to get the steering shaft/nut out. I thought I could maybe just remove the top half of the steering column and pull it out, but that doesn't seem to be working. I am in the process of pulling the whole box, but I'm not sure if I can just pull the steering shaft out of the column?
This is NOT my tractor in the picture, but one I found online. I am currently at work and do not have any pictures.
So I have removed the bolts from this half of the steering column, and it will only come up about 1 inch and is stuck. I can spin it around, but it doesn't seem to help anything. I do not see any other bolts or screws anywhere to get the rest of it up. I am not sure how to get the steering shaft and nut out of the box. I have removed the steering wheel as well. The kioti manual has the steering column all as just 1 piece, so I don't really know how to get this thing apart. Is it even supposed to come apart?
Attached is another picture of the gear (not from my tractor) that needs the bearing cage. I need to get this out of my tractor and get the new bearings/cage put on. I am struggling figuring out how to get to this part.
Thank you!
Thank you!
