3-Point Hitch New Holland 6610S Hydraulics
   / New Holland 6610S Hydraulics #1
kbright
Member
Ford 3000
All fluids and filters changed. 3-point lift will not pick up heavy equipment - need pump rebuild?
Inner rear remote raises but will not move forward to retract or float. - another rebuild?
Thanks
   / New Holland 6610S Hydraulics #2
Thanks
If all you did was change the fluids and the hydraulic filter, there's no reason why the lift should work any different than it did before you made the change. If it picked up heavy equipment before it should still do it now Your pump is a gear pump and so it should prime itself. Cycle the 3 point several times without weight on the hitch. You may have air in the lift cylinder that's hasn't been displaced by fluid.
2004 Timber King TK350 Wheeled Feller Buncher (A59213)
2004 Timber King...
Hays LTI PTAT180RD Seed Tender (A57148)
Hays LTI PTAT180RD...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
Hercules Rustic Gun Cabinet Holds 20 Guns (A57454)
Hercules Rustic...
2018 John Deere Z997R (A53317)
2018 John Deere...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
