John Deere OE Light Kit #BM25082
   / John Deere OE Light Kit #BM25082 #11
Every man has his price.
I personally would spend a few hours putting the lights on myself from parts locally purchased and save $100.
Hey, that's just me.
What is unclear is if there is anything in the "kit" besides the two lights. I'm betting there isn't. I figure the wiring harness is already in the cab. The reason I say that is with every other work light "kit" that JD sells that includes wiring harness, wire looms and wire ties, they are all broken down and have part numbers assigned. This is so you can order replacement parts in case you damage a harness or something.
If this "kit" is just two LED lights and a pair of nuts and bolts, you could get a pair of good quality LED lights for around $50 and save $180.
Some of the LED work light kits for the compact tractors cost almost $500 and you can go and buy similar lights yourself for around $60.
I realize JD has thousands of these kinds of parts but I wish they were Like Polaris. When I order accessories for my 2018 RZR S 900 I can download (and print) a complete installation guide so you know what you are getting yourself into such as with the Side Mirror Kit I got recently ►Side Mirror Kit
   / John Deere OE Light Kit #BM25082 #13
The OP can chime in when the kit comes.
Will do........................
Got the kit today. Its plug'n'Play. Has 2 LED lights, wire harness, fasteners etc. Everything needed to install. (Made in China)
   / John Deere OE Light Kit #BM25082 #16
Thanks for posting the info. That's strange that JD is not breaking down this kit in the parts system. They usually show the individual part numbers for the light assemblies, wiring harnesses and switches in case anyone ever needs a replacement. I guess they figure folks will just have to re-purchase the whole kit if they ever need a replacement lamp or wiring harness.
There are no part numbers included in the instructions either.
   / John Deere OE Light Kit #BM25082 #18
I suspect the lights are made by Grote. Do they have any model or part numbers on them?
No just a label that says made in china, no part number on anything and a label with a letter or two like on the harness that you can just make out part of in the pic. No brand identification anywhere .
   / John Deere OE Light Kit #BM25082 #20
Do the instructons show how to wire the harness?
And I notice that one of the items is a "switch bracket". So does the switch not mount in the dash?
Richard
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
