Technique to weld DOM tube to flat plate
   / Technique to weld DOM tube to flat plate #1
BigBlue1
Middle MN
JD: 2520 & x758
I need to weld about 3" length of 1" OD DOM tube to a flat piece of steel using MIG/GMAW. Both approx 1/8" thick. The contact area is very small and the V groove is quite narrow and 'deep' so I'm not sure what the right method would be. Basically like this diagram, but the plate is wider than the tube so it is harder to get to the point of contact. I've already ground a flat into the side of the tube but only a moderate one. Wondering if I should make a deeper/wider flat on the side of the tube to make that valley more accessible and less 'deep'?
Thanks,
Rob
   / Technique to weld DOM tube to flat plate #2
Bend the flat plate to a closer match to the tube,,
then, it is simply a butt weld,,
I just did that today on my SIL's RFM, one of the four wheel supports broke off,,
I had done the other side last year,, so, now both front wheels are repaired.
It was just like this mower,,
I haven't broke one of the wheels on this mower,,, YET!! :D
Here are a couple actual pictures.
I can't alter the flat plate. It needs to stay flat.
   / Technique to weld DOM tube to flat plate #5
Could you not add a piece of angle iron?
   / Technique to weld DOM tube to flat plate #6
Unless carrying a tremendous load, I don't see the problem? I'd tack it in place in 4 places. Then weld it.
   / Technique to weld DOM tube to flat plate #7
   / Technique to weld DOM tube to flat plate #8
Or if he is lucky and can find a C channel laying around that the pipe will lay in???
   / Technique to weld DOM tube to flat plate #9
If not a tremendous load I would do what you said. No need to OVRWLD though. Maybe 3/4” -1” beads on each end both sides for a 3 inch length of tube.
Edit. I just reread and material is only 1/8 inch so I would assume light load?
   / Technique to weld DOM tube to flat plate #10
Yeah, I thought of that later too. Must not be too much load.
Just weld it on, being careful to keep it aligned in the proper position.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 Chevrolet Duramax (A50120)
2015 Chevrolet...
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
Caterpillar 330FL (A50120)
Caterpillar 330FL...
2025 12V Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12V Diesel...
