Gas cylinders on an angle?
   / Gas cylinders on an angle? #21
Yeah, and WITHOUT tweakers waiting for you to turn your back for 5 minutes :rolleyes: ... Steve
   / Gas cylinders on an angle? #22
FIVE minutes Steve??? Your tweakers union???
   / Gas cylinders on an angle? #23
My tanks lean about 26 degrees. Is that too much? I store them vertical but sometimes they remain slanted like this if I have to roll them to the other side of the shop for a torch job.
   / Gas cylinders on an angle? #24
That’s a nice cart design.
   / Gas cylinders on an angle? #25
I bought it at northern tool years ago but I am not sure if they still sell them. I would like to find one about this size with large steel wheels so it would roll in the gravel driveway easily.
   / Gas cylinders on an angle? #26
Yours is the same basic design as this one I found on Facebook Marketplace. The shop only wanted a case of beer for the two carts and were happy with the $20 I gave them. Yours looks much better constructed.
I built this one for the farm when I was a kid. The large diameter wheels were necessary to roll around outside. Most likely something similar would work for you.
The bottle clamp to replace chains I only added lately.
   / Gas cylinders on an angle? #27
BT, your cart looks like it can also stand up straight; looks like the weight of the bottles would allow that. I don't think the angle would be a BIG deal, but personally unless there was a really good reason NOT to, I would opt for tipping it up straight (assuming I'm right about that option) - After nearly getting killed by someone NOT being aware OR careful with acetylene before I was 20, I tend NOT to "poke the bear" unless I already have a rocket launcher pointed at him.
I don't have any pics, but a couple of the many O/A carts (most were size 5 acetylene/330 cf Oxy) at the last place I worked (retired in 2012) were set up with full-size car tires, and heavy frames that were actually a sort of GIMBAL mount - when you tipped the cart back on its wheels, both tanks stayed vertical. Tipping it back only moved the center of gravity back a bit so you had a little weight on the handles. Most of the weldors liked 'em because you could roll up to a job, do it and move on before the other O/A sets could even be used.
Too many industrial and govt secrets in that place, so I couldn't get pics, and I never got around to making a drawing - sorry... Steve
   / Gas cylinders on an angle? #28
Maybe I better just start using it in the upright position for safeties sake. If I ever need them refilled, I will stand the cart up when cutting for sure then.
Maybe it's okay or maybe I'm just lucky, I don't know. But there has to be a reason Northern Tool quit selling them.
   / Gas cylinders on an angle? #29
   / Gas cylinders on an angle? #30
Most LWS sell carts like this. The back wheels are just a kick stand to make moving around a little safer with less weight to hold onto. This cart is how many hospitals move their spec gases around.
2012 International 7500 (A57148)
2012 International...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
2014 Chevrolet Equinox AWD SUV (A56859)
2014 Chevrolet...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
SUV (A59231)
SUV (A59231)
