Advice on potential purchase (Nortrack 3500B)
   / Advice on potential purchase (Nortrack 3500B) #121
I think Bob's onto something. Whether you keep it or sell it, its value is at its lowest as-is/where-is. It's worth more in a garage than it is in the field, and it's worth more fixed than it is broken. Do you think a roll-back will be able to move it with one track frozen? If so I think that's money well spent. Even if you end up just selling it as-is you've removed the uncertainty of how to move it. A few years ago I hired a roll-back to move a minivan and my recollection is it was reasonable, maybe $85.
   / Advice on potential purchase (Nortrack 3500B) #123
Bob,
Yuchai Dozer Brake Adjustment CTOA
Looking at this thread from CTOA, it seems this is as far as I have to go to fix my dozer. Yes, if that's the issue. When you state the bull gear shaft is broken, that is the part shown in post #36155 correct?
Yes.
Which is the same part from the cirgle g link below. right?
No.
252L.39.53B ( Semi axle gear ) | Jinma Tractor Parts, Farm Pro Tractor Parts | Circle G Tractor Parts
That is the pinion shaft and gear (semi axle gear #6). It drives the bull gear.,
If you have the identical situation as the CTOA thread - broken bull gear/sprocket shaft (drive shaft #19), then this is the main part that you need, plus any gaskets and seals:
Z�5.39.537 ( Drive shaft ) | Jinma Tractor Parts, Farm Pro Tractor Parts | Circle G Tractor Parts.
   / Advice on potential purchase (Nortrack 3500B) #124
If that is the case, I would also consider replacing the bearings too, as they have been run in oil with metal shavings.
Bob,
I just wanted to thank you for all your help with the Nortrack that I had. I did end up getting a roll back truck, and yanked it out of the pasture. Sold it to another fellow for 5k. Last I heard he was able to repair it, and uses it today.
I went another route, Kobelco mini.
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
