My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #81
Yup, got a dozen or so of the Costco 4' leds for light, stayed "old school" (fitting, dangit) for the "norusto" "heat bulbs" - keep a little "milkhouse" heater blowing under the PM66, 100 watters under jointers/planer/bandsaw/mill tables, and the one router table that's cast iron. small stuff stays in 33 cu ft dead freezer with another 100 watt (set about 1/2 power with speed control) - so far, knock on wood (as long as I don't have a headache :D ) ... Steve
Pic #3 Alignment gauges. "Fragile keep flat". Is the weight on top of it your strategy? :D
   / My Garage/Shop Heater Install #83
Nope, just too lazy to write it THREE times; applies to the WHOLE STACK :D ... Steve
   / My Garage/Shop Heater Install #84
Eventually (yeah, right) I hope to gut that freezer and come up with a "circulation friendly" but more efficient shelf system - probably AFTER I find a good bulk sale on those "tuits" :confused: ... Steve
The good news... propane tank delivered and hooked up.
The bad news... I can't get the heater working. It will light with igniter but it won't stay lit once igniter shuts off! I just posted a HELP thread on Garage Journal. Also looking for any thoughts here?
   / My Garage/Shop Heater Install #86
I’m not qualified to provide advice but letting you know I’m “here” for you. Standing by as your support troll.
I checked the inlet pressure... it's reading 11.2 in H2O. Acceptable range is 11 to 14. Checked the outlet (manifold pressure) and it is reading 9.5 when the igniter is on. Once it stops clicking the flame extinguishes. :confused3:
   / My Garage/Shop Heater Install #88
picture of control ?
Here is a pic showing manometer hooked up to outlet pressure tap.
   / My Garage/Shop Heater Install #90
You holding it on until Themocouple gets hot .....
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2-JACK STANDS (A55745)
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
