New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas?
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #22
Not enough factual information. Ask the previous owner.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #23
I fill up holes like that all the time. Nearly 30 years ago, I had a lot of trees cut, then sheared the stumps. Now, as the stumps rot out and cave in, I have holes.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #24
Tie a heavy sinker on your fishing rod and drop it in to measure dept.
I agree. If it is deep and the water table is that high then you have an bonus well. Use it to water gardens and lawn. You may be able to tap into it as a ground source heatpump - free energy source.
If it was septic related, I expect your nose would have warned you! The previous owner should be able to tell you.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #25
Looks like a septic drain to me. The one at my country house doesn't go straight down, but the water coming out is clear and has no odor.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #26
Same here....no odors from my leach field drains.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #27
It screams field tile stealing dirt to me. You get a field tile, a lot of older ones were clay, they get a bad joint, and as water flows through it the dirt gets sucked away. You can dig down and repair it or just fill it in. A tile probe would let you know for sure.
Bought my house 20 years ago. The septic tank leach field had plastic tubes sticking up out of the ground; nobody could tell me why. In addition, the drainage from my leach field extends about 200’ from the field itself.
So.....a remote possibility is that it has something to do with a leach field (assuming you’re on a septic system).
I agree, it's most likely a broken clay tile or old tree stump.
I had a hole just like that about 10 years ago. I did the hoe handle measurement and also found no bottom. So I loaded the bed of my JD Gator half full with soil from an old fence line to put down the hole.
The next year the hole came back with a vengeance. So I got a full Gator bed load of soil from the old fence row and dumped down the hole. After a couple of summer months and rains, I added another half load to fill it and made a small mound for some settling for it to level off. That was several years ago and now it is forming a slight depression, but no hole yet.
I have another depression/hole beginning about 100 feet up hill from that old hole now. This hole will be easier to deal with because I have a tractor/loader now. The first time around it was all shovel work.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #28
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #29
This thread is NOT like Pallets in a field thread.......
The OP has already posted more than Sparcs!
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #30
The YouTube video helps for those that are comments without watching.
My suggestion is to find your plot plan for the property and see if there are any clues from that. If you don't have it, then talk to the county records folks for a copy. It can also be found in any deed/purchasing records you should have.
Quick Attach Stump Grinder Mini Skid (A56436)
Quick Attach Stump...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A57453)
2007 Chevrolet...
3 Point Attachment (A57454)
3 Point Attachment...
Misc Pallet of Winch, Tools, and Driveshaft (A57454)
Misc Pallet of...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
