How may tubes of grease do you go through greasing at 50h intervals?
   / How may tubes of grease do you go through greasing at 50h intervals? #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I am looking for a ballpark figure, on a CUT (say a CK2610) with FEL, maybe a rotary mower or flail mower. Just trying to see if going with a bulk grease pump would be worth it, on a cost per year basis.
I'm a firm believer in buying once, and I like the idea of the small (3 gallon) pneumatic pump, that I would only have to fill once, and would not have to worry about leaking (my standard lever type gun leaks like sieve). I like the savings that come from buying a 3 gallon tub vs 14oz tubes also.
Now, if I only need (1) 14oz cartridge every 50h on average, I may just get an Alemite 555 gun with a lock n lube barrel cap and be done with it. I already have a locknlube tip :)
PS I understand that 50h is a recommended greasing interval. If more frequent greasing is recommended, or you grease more often, just put in in tubes/50h terms.
   / How may tubes of grease do you go through greasing at 50h intervals? #2
I just buy a case of tubes and grease the loader every 8 to 10 hours of use the rest every 50 or so....
   / How may tubes of grease do you go through greasing at 50h intervals? #3
Pneumatic doesn't allow for any "feel". Too easy to blow out a seal or, just plain over grease a pin.
Fleet mechanic banned them years ago.
   / How may tubes of grease do you go through greasing at 50h intervals? #4
I don't have an answer, but if I was only greasing a small CUT, a tube of grease would last a long time. I can't imagine there will be much in the way of savings going with bulk.
   / How may tubes of grease do you go through greasing at 50h intervals? #5
Old school pistol pump with lock n lube end .......Lucas Xtra Heavy Duty Grease (Green )
   / How may tubes of grease do you go through greasing at 50h intervals? #6
If I only need (1) 14oz cartridge every 50h on average, I may just get an Alemite 555 gun with a lock n lube barrel cap and be done with it. I already have a locknlube tip :)
Kubota Loader greasing interval is every ten hours of use. I use black Lithium with Moly "EP" grease.
I use slightly more than 1-1/2 grease cartridges per fifty engine hours. That is 3-4 Loader lubes + one thorough chassis lube, including the Loader.
   / How may tubes of grease do you go through greasing at 50h intervals? #7
AND.....?
   / How may tubes of grease do you go through greasing at 50h intervals? #8
AND.....?
And at that rate the payback on any kind of bulk system will be measured in decades, if not centuries when opportunity cost is considered.
Edit: A cheap bucket grease pump is $100 at Northern Tool. A decent quality 5 gallon pail of #2 Mobil grease will run $100. That will yield 40 tubes of $5.00 grease. I’ll look elsewhere to “save” money.
   / How may tubes of grease do you go through greasing at 50h intervals? #9
I have one but do not use it for bearings as said here no feeling on grease going into the bearing. I realized I was not sure spindle bearings on mowers might not be getting the grease they needed.
   / How may tubes of grease do you go through greasing at 50h intervals? #10
50 hours isn’t nearly enough. I grease every few hours of continuous use. Most machines recommend 10 hours but that’s probably machine hours and not consistent use. It takes about a tube to grease my backhoe. A tube should grease a tractor several times. Btw Walmart sells a pretty good grease for $2 a tube.
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2012 PROCO KILL TRAILER (A55745)
2012 PROCO KILL...
ALLISON TRANSMISSION (A55745)
ALLISON...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2008 CAT 305C (A53317)
