Jinma 354 4wd 2012 540 PTO stuck on
   / Jinma 354 4wd 2012 540 PTO stuck on #1
Fishheads
Jinma 354 4wd
Hi all.
Hoping for some insight. I was running my PTO driven bush hog and the lever that changes from 540 - N - 1000 got stuck. I fiddled clutch in, clutch out and it started working again. Now I cannot get it to stop spinning in 540. Lever moves in the proper 3 option but it is always running on 540.
Any ideas ?
   / Jinma 354 4wd 2012 540 PTO stuck on #2
Check to see if the roll pin has been sheared off.
ok thank you ill take a look. Think there is a panel i can take off at the back to have a look. picture attached you think im alright to take off this panel ?
   / Jinma 354 4wd 2012 540 PTO stuck on #4
Ok, thank you ill take a look. Think there is a panel I can take off at the back to have a look. Picture attached. You think I'm alright to take off this panel ?
The roll pin I'm referring to will be at the base of the shift lever, not inside the case.
   / Jinma 354 4wd 2012 540 PTO stuck on #5
I don't have that panel on mine but I'm pretty sure it's for attaching a backhoe hydraulic pump.
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
