Jinma 354 4wd 2012 540 PTO stuck on
   / Jinma 354 4wd 2012 540 PTO stuck on #1
Fishheads
Jinma 354 4wd
Hi all.
Hoping for some insight. I was running my PTO driven bush hog and the lever that changes from 540 - N - 1000 got stuck. I fiddled clutch in, clutch out and it started working again. Now I cannot get it to stop spinning in 540. Lever moves in the proper 3 option but it is always running on 540.
Any ideas ?
   / Jinma 354 4wd 2012 540 PTO stuck on #2
Check to see if the roll pin has been sheared off.
ok thank you ill take a look. Think there is a panel i can take off at the back to have a look. picture attached you think im alright to take off this panel ?
   / Jinma 354 4wd 2012 540 PTO stuck on #4
Ok, thank you ill take a look. Think there is a panel I can take off at the back to have a look. Picture attached. You think I'm alright to take off this panel ?
The roll pin I'm referring to will be at the base of the shift lever, not inside the case.
   / Jinma 354 4wd 2012 540 PTO stuck on #5
I don't have that panel on mine but I'm pretty sure it's for attaching a backhoe hydraulic pump.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
