How may tubes of grease do you go through greasing at 50h intervals?
   / How may tubes of grease do you go through greasing at 50h intervals?
Many decades ago my father got grease in the 35-50# pails, and we would fill grease guns from them.
Some times we had a pump to load the grease guns with, much of the time you cleaned the grease gun unscrewed the end and used the rod to pull the grease using suction into the grease gun.
what a filthy dirty gritty grimy mess that always ended up being.
Then especially when it was cold out the grease gun would only be 1/2 filled and air pockets in the balance, having to loosen the end and try and purge the grease out,
way to many years of that crap.
Much working equipment gets greased every day, and some fittings may even be gotten a few times a day if experience has shown the need to do so.
The farm gets tubes of grease by the case and sometimes multiple cases. The grease guns work better, the grease does not get contaminated, air pockets and purging are mostly a thing of the past. It is quick, easy and clean to change out a tube. There will be times when we may go thru a couple of tubes per day. Many times air is not available where we are greasing and prepping equipment for the day. As far as the foot operated ones to many fittings are positioned were having to get a foot onto that pedal would be a contortionist joy.
So you boys go with the big buckets and pails, I'm for the tubes even when I'm using my pneumatic grease gun.
I may get a battery gun sometime, I keep looking but that's a lot of money to save very little work or time.
Interesting. I always thought bulk suction fill would be a mess, with potential grease contamination, but port filling? Besides maybe taking a bit of time (depending on your volume per stroke on your bulk pump), the only challenge I would see there is stopping in time, before you overwhelm the piston seal. And to avoid this, you could just stop a bit short and underfill. Probably good savings too, even with the purchase of a pneumatic pail pump to make refilling easier.
   / How may tubes of grease do you go through greasing at 50h intervals? #32
The pump was a royal pain in the a--, especially in the winter when the grease was cold it would suck air and lose prime.
In the summer it would work but was slow, I couldn't hazard a guess as to how long now but it was much longer then changing out an empty tube and replacing with a new one.
I think it would take decades to pay for the cost of the pump for most people over the cost of tubes.
   / How may tubes of grease do you go through greasing at 50h intervals? #33
I probably use enough grease to justify the cost of a better system but with my machine usually being on a job somewhere I haven’t found anything besides the tubes to be practical. I’m not interested in the huge mess of trying to refill a gun plus they don’t last long enough to help me much and I’m not carrying around a 5 gallon bucket of grease and for sure not a 20 gallon barrel.
Thanks for all the real world experiences. While I still WANT the large/bulk dispenser with pneumatic assist, the truth is grease availability will likely make the choice for me. I can't find anyone local who has the grease I want in 35lb pails, but I can get tubes shipped without issue. I will be replacing my level action gun with a pistol grip though. In my effort to keep it out of the dirt, I managed to put about 25% of the grease I dispensed on me. Maybe a swivel hose would help. I did like the lock and lube tip a lot better than the 30 year old tip I had on there though. Pretty sure this time around at least some grease made it into the zerks.
   / How may tubes of grease do you go through greasing at 50h intervals? #35
5,��� PSI Air-Operated Grease Pump | Princess Auto
Ive had good luck with one of these for the last 5 years. I only added a 16 inch whip and LNL. Grab one now, CDN$112 on clearance with free shipping.
Has outlasted all my hand pump grease guns so far and way less mess and frustration than cartridges.
   / How may tubes of grease do you go through greasing at 50h intervals? #36
I’ll just add I’ve bought a lot of tools over the years, a few I thought I needed but didn’t, but a battery operated grease gun was one of the best things I bought. I only have one tractor and only about 100 hours per year and I still like it.
Thanks mikester, I was eyeing this, and your solid review put me over the top. I ordered one, at the clearance price with free shipping these days, it is a no brainer.
Now if anyone knows where I can get a 35lbs pail of Paragon 3000, Royal Ultra 865HD or Amsoil Synthetic Multi-Purpose grease shipped in Ontario, Canada at a decent price, I'm all ears :)
I'll even entertain similar performing products, if you know of any. Trying to stay away from the 5% moly stuff, even if it is better for the pins and shock loading. Staining power is also off the charts :)
   / How may tubes of grease do you go through greasing at 50h intervals? #38
I grease everything - every ten hours of use. Grapple, tractor and rear blade. I use a DeWalt 20V Max gun and one tube of nasty black grease. I have a Lock-N-Lube on a hand pump gun. The Lock-N-Lube will not fit into many of the recessed zerks on the tractor. So...... I gone to the DeWalt exclusively. It fits everywhere.
   / How may tubes of grease do you go through greasing at 50h intervals? #39
Once grease is open it should not sit around. I have seen people with grease guns hanging in cold barns for months if not years on end, bad practice (separation and contamination). ONLY buy enough to last 6 months and store in controlled climate, see chart.
source: 10 Ways to Improve Lubricant Storage and Handling
Synthetic Polymeric Off-Road Grease, NLGI #2
   / How may tubes of grease do you go through greasing at 50h intervals? #40
Search for local lubricant distributors in your area. You might have luck with your local fuel delivery guy, some will do special orders.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
More info coming soon! (A50322)
More info coming...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A55745)
2011 FREIGHTLINER...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
