How may tubes of grease do you go through greasing at 50h intervals?
   / How may tubes of grease do you go through greasing at 50h intervals? #41
Now if anyone knows where I can get a 35lbs pail of Amsoil Synthetic Multi-Purpose grease shipped in Ontario, Canada at a decent price
Order it direct from AMSOIL and get 25% off and free shipping ►Save up to 25 percent on AMSOIL products
They have distribution center in Toronto.
Once grease is open it should not sit around. I have seen people with grease guns hanging in cold barns for months if not years on end, bad practice (separation and contamination). ONLY buy enough to last 6 months and store in controlled climate, see chart.
source: 10 Ways to Improve Lubricant Storage and Handling
Synthetic Polymeric Off-Road Grease, NLGI #2
I guess I am about to find out how bad grease is after 5 years... I wonder if this chart is conservative. Has anyone done a study on this? Does it matter if you keep the grease sealed, or even under vacuum?
   / How may tubes of grease do you go through greasing at 50h intervals? #43
How many tractor are you greasing ?
Still just one tractor, and one garden tractor/mower.
   / How may tubes of grease do you go through greasing at 50h intervals? #45
Would just 1 case of grease and a hand grease gun work .... seems like a lot for just two tractors not to be a a**hole but......
I know it's way overkill. I do that a lot ☺
One thing is for sure, I'm not throwing out a pail of grease after 6 months, just because. Shelf life is 3 to 5 years, unopened. I really don't see how open containers go down to 6 months, unless you are scooping out the grease with a sandy wet shovel and you store the pail near a steam boiler.
Good info on lithium vs calcium carbonate grease though. Lithium seems to have twice the shelf life, no matter where you start. Another advantage, besides pumpability.
   / How may tubes of grease do you go through greasing at 50h intervals? #47
If you lived closes you could use this I have not used it in twenty years...........air grease gun.jpg
   / How may tubes of grease do you go through greasing at 50h intervals? #49
I use my loader primarily for snow removal and grease EVERY time I use it. So I grease the loader about every 3+/- hours. Sure my loader arms are slobbering grease and I may be wasting it, but grease is way cheaper than loader pins and bushings and not as hard to remove.
I've got a battery operated cartridge gun. I get the grease a case of 10 tubes at a time.
   / How may tubes of grease do you go through greasing at 50h intervals? #50
No I just don't use it I have a little cart with a gear oil pump also....And a 25 foot auto reel grease hose..grease cart.jpg
2014 Freightliner M2 106 24ft Box Truck (A52377)
2014 Freightliner...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
230112 (A53422)
230112 (A53422)
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
