Info about hydraulic fittings
   / Info about hydraulic fittings
ruffdog I think you win the prize!
The male is stamped 6-6mb The other end is 6fjx The two ends screw into one another. Who would have guessed MB is Male Boss
Thanks so much to all that played.
Dave
One more question. is this -AN6 also called a 3/8 even though the actual threads are 9/16"
   / Info about hydraulic fittings #13
Yup, in most hydraulics it's the tube size that's spec'd; the numbers 6,8,10, etc, are 1/16" increments so a 6 is 3/8 tube, 8 is 1/2, etc. AN stands for Army/Navy, bit different specs in some ways but IIRC, will mate up to JIC fittings. Stated thread sizes are gonna be bigger, no way around it.
I was 33E at Devens, they needed 2 more instructors as my class was graduating so took the top two in the class, I was one of 'em. Taught there a couple more years, then somebody thought an instructor would make a good troubleshooter, so I got sent to several different parts of the world to "make things better".
Ended up after my 4 years working at Memorex in the SF bay area, started my own video repair biz with ANOTHER agency guy, later launched a startup audio/video/calibration biz with 2 other guys in Honolulu, couple years later Memorex asked me to come back (this time to their digital development lab), everything there was fun EXCEPT the management so after a couple years we moved back to Oregon after my dad died - spent the next 35 years in industrial automation/control in rare metals plants, finally pulled the plug on that 8 years ago.
The hydraulics I play with now are a bit smaller than the ones were at work; none of my tractors have 300 horse hydraulic pumps moving 3 and 4 foot diameter cylinders on 1000 ton presses :rolleyes:
That's the REALLY truncated version, but probably enough "thread drift" for now... Steve
   / Info about hydraulic fittings #14
IF you havent figured it out, FJX typically refers to JIC.
The 6 means its a 3/8
Tube sizes are in 1/16'ths
SO you have a 3/8 male o-ring boss fitting. ORB or MB or whatever people choose to call it in your reigion.
And a 3/8" common JIC
Yes the threads are the same for ORB and JIC fittings. But their method for sealing is different
Roger Roger LD1
   / Info about hydraulic fittings #16
Next time you visit your hydraulic supply store ask them for a quick reference wall chart or catalogs.
and the naked girl calendars (in December.).
<snip>
</snip>
I looked carefully at your pictures and did not see the play girls.
Ordered the hoses online yesterday and they shipped today.
Thanks to all those that helped me out during the pandemic. Will be spraying them with bleach initially.
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
Golf Cart (A51694)
Golf Cart (A51694)
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
INSPECTION (A51573)
INSPECTION (A51573)
