Neighbor dog on my property harassing wildlife
   / Neighbor dog on my property harassing wildlife #371
But you will lie to them when confronted, that speaks volumes about you're character.
Sorry, someone that cant or wont control their animals does not deserve an explanation!!
   / Neighbor dog on my property harassing wildlife #372
Rubber buckshot is readily available as well as rubber bullets for the larger calibers. I have some for .45 acp. No powder just a primer and shove in the rubber bullet into the case by hand. works well. They are flat on the end. Not a lot of range as they fall to the ground pretty quickly (probably 20 yards maximum) but up close they will put an errant animal on the run. Of course they are single shot at the pistol won't cycle but that is usually all you ever need.
Here is some for .38/357 That should work well in revolver giving multiple shots.
X-Ring Rubber Bullets 38 Cal (357 to 358 Diameter) Box of 5
I have plastic rounds like that for my 44 mag, just primer fired.. same thing basically.
Just looked at your link, bottom left pic in red
   / Neighbor dog on my property harassing wildlife #374
yeah, years ago when the "fast draw" thing was a popular sport, a lot of guys made wax bullets by just taking primed cases and shoving them into a layer of paraffin melted into the bottom of a cake pan. The mouth of the cartridge case cutting into the paraffin and lodging the "bullet" all in one go. They probably would have a very short range, but it might be enough to sting out to 10 yards, maybe.
   / Neighbor dog on my property harassing wildlife #375
Rubber
Rubber Bullets would be great, I could do that! What does it mean "to enlarge the flash hole to prevent primer set-back"?
   / Neighbor dog on my property harassing wildlife #376
Primer set back can occur because there is no powder charge to slam the primer back into the breechface. And the primer charge pressure can move the primer back a little unless the flash hole is enlarged a bit (think small drill bit run thru each case) to prevent the primer charge pressure from "setting back " the primer. In a revolver, this setback, if it occurs could "tie up" a revolver and prevent cylinder rotation. Be sure to mark these few cases you prepare this way. A lot of this depends on how tightly the primers seat into the primer seats. I used rubber bullets in a .45 acp autoloader and of course I didn't care about primer setback. But in a revolver, this may need to be done. Mark the case heads with a sharpie and don't mix these cases up with your regular cases with normal primer flashholes. Of course we are assuming you are a reloader to start with. Some may think these bullets are loaded ammunition which of course they are not. They are just rubber bullets to load into cases by reloaders. Of course the rubber buckshot loads I pointed to are complete loaded shells ready to go.
   / Neighbor dog on my property harassing wildlife #377
Thanks for the explanation, made perfect sense.
   / Neighbor dog on my property harassing wildlife #378
Looks like dog nuisance talk morphed into a gun thread :laughing:
   / Neighbor dog on my property harassing wildlife #379
Just waiting on the OP to report back on what happened. :)
   / Neighbor dog on my property harassing wildlife #380
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
