ryanlhunt4
- Joined
- Apr 18, 2020
- Messages
- 3
- Tractor
- Ford 2000
Hello all. I have a check valve leak on the lift cover assembly of my 1966 Ford 2000 3-CYL Gas Engine. I found out recently that the transmission fluid level was extremely high. I don't know if it could have been over-pressurized or if it is a failed o-ring. If it is failed o-ring, can this be replaced without removing the entire lift cover assembly?
I've cleaned and dried thoroughly and I believe this is where the leak is. It doesn't look like it is the gasket.
Thanks,
Ryan
Thanks,
Ryan
