Mahindra 4530 PTO lever repair
   / Mahindra 4530 PTO lever repair #1
Ravine
Mahindra 4530
My 2014 4530 recently had the PTO lever make a grinding noise and then go completely limp. It was flopping back-and-forth. I knew it was a pretty serious event, the PTO would not engage . I was able to repair it by pulling out the PTO linkage and fishing out the parts from the transmission housing. I took some Pictures of the process since I couldn稚 find any help on any of the forums. It was a broken shear pin in the linkage. I had to loosen and pull away the Rear brake drum to access the Three bolts. After that, the linkage came out, missing the PTO shaft lock. A magnet was able to capture the missing pieces. When putting it back I had to turn the PTO shaft a little by hand to line it all up. Bolted pretty easy after that .
   / Mahindra 4530 PTO lever repair #2
Ravine, I am having the same problem. Do you have pictures or anything showing what you did. It would be greatly appreciated.
   / Mahindra 4530 PTO lever repair #3
Ravine if you are still here. I am having the same problem. Would you have pictures or info on this that I could get from you.
Thanks in advance
   / Mahindra 4530 PTO lever repair #4
Seem I have the same problem. Were you able to get your PTO fixed?
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
WB Mower (A50120)
WB Mower (A50120)
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
