Mahindra 4530 PTO lever repair
   / Mahindra 4530 PTO lever repair #1
Ravine
Mahindra 4530
My 2014 4530 recently had the PTO lever make a grinding noise and then go completely limp. It was flopping back-and-forth. I knew it was a pretty serious event, the PTO would not engage . I was able to repair it by pulling out the PTO linkage and fishing out the parts from the transmission housing. I took some Pictures of the process since I couldn稚 find any help on any of the forums. It was a broken shear pin in the linkage. I had to loosen and pull away the Rear brake drum to access the Three bolts. After that, the linkage came out, missing the PTO shaft lock. A magnet was able to capture the missing pieces. When putting it back I had to turn the PTO shaft a little by hand to line it all up. Bolted pretty easy after that .
   / Mahindra 4530 PTO lever repair #2
Ravine, I am having the same problem. Do you have pictures or anything showing what you did. It would be greatly appreciated.
   / Mahindra 4530 PTO lever repair #3
Ravine if you are still here. I am having the same problem. Would you have pictures or info on this that I could get from you.
Thanks in advance
   / Mahindra 4530 PTO lever repair #4
Seem I have the same problem. Were you able to get your PTO fixed?
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
