Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #13,153
I picked up another saw. I wanted a saw a little lighter than my 372 but would still cut decent. I really needed another saw since I’ve got 2 people working pretty often was the biggest reason. I’ve got some 50 cc saws but they don’t cut to suit me. The best value I could find was a Makita branded Dolmar. I haven’t used it a lot but so far I’m pretty happy with it.
   / Tractors and wood! Show your pics #13,154
I picked up another saw. I wanted a saw a little lighter than my 372 but would still cut decent. I really needed another saw since I致e got 2 people working pretty often was the biggest reason. I致e got some 50 cc saws but they don稚 cut to suit me. The best value I could find was a Makita branded Dolmar. I haven稚 used it a lot but so far I知 pretty happy with it.
Nice 60cc saw! When did Makita stop making them in their blue/green color?
   / Tractors and wood! Show your pics #13,155
I have only taken my loader off once in 21 years of ownership and 3000 hours of use, and that was when I had to replace the clutch and split the tractor.
Even for doing rear end work like tillage, I will scoop some dirt in the front bucket to put a little more weight on the front end to get the front tires to bite a little better.
   / Tractors and wood! Show your pics #13,157
Winter 2019
The only thing lifting the front tires is the winch.
Spring 2019
My neighbors were working across the road with their Timberjack, and I had already warned them I may need a rescue.
Instead I ran a chain from the bucket to a tree, and pulled myself out that way.
Winter 2020
There was a stream running through here long ago, which gradually filled in with sediment. Pre setter or later, who knows?
The front tires dropped into the old channel.
Dang, the one above always posts upside down. :( Same place as above, different view.
Your lucky you’re not here in Oregon running through the creeks etc can land you in jail worst case best a slap on the wrist. Do you guys have set back or buffers on creeks or wet lands?
   / Tractors and wood! Show your pics #13,158
It's no longer a stream, the only reason I say that there was a channel there at one time was because my front tires were following it instead of coming out on the other side. I was trying to freeze it down, piling more snow on to form a crude ice bridge. You can see how that worked out for me.
Trust me, I deal with our laws on a regular basis; I would never have posted that on a public forum, if there was a violation involved.
   / Tractors and wood! Show your pics #13,159
I believe my tractor is 200 hrs, but I don't think I've ever let it go that long.
SR
Yeah, I think mine is 200 also.. seems like a long time..
   / Tractors and wood! Show your pics #13,160
You cant drive through your own creek in Oregon????
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2015 Ford Transit 350 Passenger Van (A55788)
2015 Ford Transit...
