22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine.
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have an old 16hp B&S cast iron engine model 325431-0135 that I would like to use on my log splitter.
I have looked for pump adapters that directly mount on PTO face with no luck.
Is there an adaptor that will mount a 22 gpm pump to this beast?
I would really like to keep this old iron in service. They sound and run very smooth and crank out 25.8 ft-lbs of torque (13.3) hp at 2700 rpm.
Thanks
90cummins
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #2
Do you have a picture of it, and have you measured the bolt pattern?
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #3
I do. The photo is the PTO side without the closure cover.
The OD of the closure cover Is 6.5 inches and the bolt circle outside that is approx 7-5/8.
I checked surplus center and nothing looked compatible.
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #8
Is this a 2 stage pump for a log spiltter or a single 22 GPM gear pump?
Before spending any money, check the HP requirements for that pump. Unless it's a two stage pump, you don't have enough HP for a pump that big.
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #9
According to this, that 16hp motor could provide about 16GPM @ 1500 PSI.
From here:
Horsepower Calculator - Metaris Hydraulics
Formula: HP = PSI * GPM / 1714
PSI is gauge pressure in pounds per square inch; GPM is oil flow in gallons per minutes.
Rules-Of-Thumb:
Horsepower for driving a pump: For every 1 HP of drive, the equivalent of 1 GPM @ 1500 PSI can be produced.
Horsepower for idling a pump: To idle a pump when it is unloaded will require about 5% of its full rated horsepower.
   / 22 gpm pump adaptor for 16hp cast iron Briggs & Stratton engine. #10
I wouldn't run much less than 2500 PSI for a log splitter and that would require 32 HP at 22 GPM, using that calculator Moss provided.
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
