Massey 1225 PTO problems
   / Massey 1225 PTO problems #1
rtyndallnc
Member
Angier, NC
Bob-Cat Pro7000, Bob-Cat Pro6000,Troy-bilt Mustang RZT 50, Massey 1225, Long 460, Kubota ZD25
Greetings to all
I have a 1999 MF 1225 Hydro that has a rear and mid PTO with a 1232 60" belly mower attached. Recently I have experienced a problem where after I have been using the mover for a while and have to turn the PTO off to move something out of the way or just take a break it will not come back on. If I let it sit for an hour or so it is good to go again. I have checked the switch and that seems good. There is a relay under the seat that seems to be ok (gonna replace it anyway). I have heard someone talk about a solenoid for this tractor but I cannot find where that is. Does any one have any suggestions as to what this may be?
I assume the toggle switch powers an electric clutch somewhere that then engages to turn the gears.
Thanks to all
   / Massey 1225 PTO problems #2
Greetings to all
Thanks to all
On my MTD Pro zero turn I was having problems are cutting haft the back yard, disengage and it wouldn't reingage. I'd let it sit a while and it would reingage. I put a trickle charger on it and i think I discovered the problem. Low voltage to the electric clutch. The battery is two years old which is kind of stretching it. Could it be your battery getting pulled down?
Not likely on this tractor. It uses a car size battery and has a alternator also. Battery is strong and alternator is at correct output.
I have a Troy-Bilt zero turn. On any mower that has a battery there is a charging system for that. Most have a generator under the flywheel. If your electric clutch was kicking out due to low voltage there is a problem with that system, either in the generator itself or the wires somewhere along the way. Once the mower is running it should be self powered even if the battery went completely dead. As long as that trickle charger is doing the job I don't know that I would bother with fixing it but if you have the right tools its not very hard.
Thanks for the reply though.
   / Massey 1225 PTO problems #4
Greetings to all
Thanks to all
I just ran across this thread... i have a MF 1225... the last year the pto hesitated a couple seconds before it kicked on running belly mower 1232. The first use of 2020 it shut off & wont start back up. Getting 12 volts at connection under the seat... bypassed toggle switch..nothing. Was wondering what ever happened with your PTO prob?
There are 2 things that you can check. 1. There is a relay mounted behind the seat that can go bad. If you have power you should either hear that click or you can feel it when you throw the PTO switch. The other thing is a solenoid. This is what was wrong with mine. It finally quit all together last year so I had to replace it. It is Massey Ferguson part number 3605668M91. It is very easy to change but you have to move some other things out of the way to get to it. I bought mine from Jacks small engines and it aint cheap ($350.00), but I have had no problems with the PTO since then and I wasn't going to let a $350.00 part stop an otherwise functional machine from working.
Jacks Small Engines Search
When I get home I will attach a pic of the relay and the solenoid.
It is part number 2 in this diagram.
Login
   / Massey 1225 PTO problems #7
Thx for response & info!! In the process of getting my hands on a service manual... I may reach out again! Thx again!
   / Massey 1225 PTO problems #8
I'm having the same problem with my 1225. Does anyone happen to have the relay part number? I'm just going to switch out both at the same time. Thanks.
As copied from the Agco parts book. 3707981M91
Login
   / Massey 1225 PTO problems #10
Could someone get a pic of these parts-both the relay and the solenoid?
I would like to see what makes these parts so expensive.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2000 GMC C6500 SINGLE AXLE BUCKET TRUCK (A57880)
2000 GMC C6500...
2013 Ford F-150 (A55973)
2013 Ford F-150...
