L5740 hydraulic add on questions
   / L5740 hydraulic add on questions
A crossover relief valve is cheap & won't let line pressure spike to high. It's a more universal solution to as it will work just fine with a cylinder or a motor. It's also the simplest solution. The more complex & fancy things get, the more I appreciate simple system that just work with fewer failure points.
Thanks, that is a solution I did not know existed. That will most likely sway me away from another dedicated motor spool and control, thus saving me money and a more complex install. I appreciate it!
   / L5740 hydraulic add on questions #12
Any relief valve will heat up oil as it pushes open the valve. In the case of a PHD that will be insignificant amounts of heat. It might get toasty if it was a heavy rotary cutter or something with tons of momentum. Those typically have just a check valve so there is no resistance to flow when going into relief. No heat issues, but it means the circuit can't be run in reverse (not an issue for a mower, a deal breaker for a PHD & other stuff).
   / L5740 hydraulic add on questions #14
Yes. Most CUTS are 10gpm & 2,500psi so that would be appropriate. I'd set it to the top of its range a bit over 2,500psi. It comes at only 1,300psi by default.
Thanks for verifying.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
KENWORTH T800 (A50854)
WASTE OIL TANK (A50854)
WASTE OIL TANK...
