L5740 hydraulic add on questions
   / L5740 hydraulic add on questions
A crossover relief valve is cheap & won't let line pressure spike to high. It's a more universal solution to as it will work just fine with a cylinder or a motor. It's also the simplest solution. The more complex & fancy things get, the more I appreciate simple system that just work with fewer failure points.
Thanks, that is a solution I did not know existed. That will most likely sway me away from another dedicated motor spool and control, thus saving me money and a more complex install. I appreciate it!
   / L5740 hydraulic add on questions #12
Any relief valve will heat up oil as it pushes open the valve. In the case of a PHD that will be insignificant amounts of heat. It might get toasty if it was a heavy rotary cutter or something with tons of momentum. Those typically have just a check valve so there is no resistance to flow when going into relief. No heat issues, but it means the circuit can't be run in reverse (not an issue for a mower, a deal breaker for a PHD & other stuff).
   / L5740 hydraulic add on questions #14
Yes. Most CUTS are 10gpm & 2,500psi so that would be appropriate. I'd set it to the top of its range a bit over 2,500psi. It comes at only 1,300psi by default.
Thanks for verifying.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
KENWORTH W900 (A50854)
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
