TC33D loss pf power when going up hill
   / TC33D loss pf power when going up hill
The part I disconnected I thought was the solenoid shut off arm.
   / TC33D loss pf power when going up hill #13
The solenoid is at the rear of the pump and directly contacts but is not connected to the fuel rack. The governor linkage goes into the governor which is located in the timing cover. If you had the barrels out of the pump housing you are screwed. They need to be installed then adjusted on a test stand.
Power problem seems to be resolved. After 3/4 of a tank of fuel with Lucas injector cleaner a new fuel filter and air filter everything seems to be much better.
I will provide another update after I get it in the field.
Thanks for all the assitance.
   / TC33D loss pf power when going up hill #15
Nice, sounds you lucked out then!
2013 BMW 328I (A56859)
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
JOHN DEERE 12' (15) ROW GRAIN DRILL (A57192)
JOHN DEERE 12'...
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
1992 Pine 53ft. T/A Dry Van Trailer (A55852)
1992 Pine 53ft...
